hjtrbo Bronze Donating Members 317 Member For: 13y 8m 5d Posted 01/12/22 10:02 AM Author Share Posted 01/12/22 10:02 AM Pleased to say she's up and running. First 30km run in, just pulling a few gears up to 3,500rpm with moderate to mild load then backing off and repeating. Pulled the oil filter apart, nothing of concern thankfully. Will send it this weekend and work on a 98 tune for it. Meth tank is going to work. First try picked up the factory washer bottle mounts without issue. Can do with some optimising for version 2, but good enough to move forward and commit to the install with this version. For version 2, I need to double check the fog light position and see if I can add in some more volume around it and there is also opportunity to add volume in the void just below the head light. 3 Link to comment Share on other sites More sharing options...
hjtrbo Bronze Donating Members 317 Member For: 13y 8m 5d Posted 19/12/22 11:15 AM Author Share Posted 19/12/22 11:15 AM 2nd time around. Engine out. Learning curves... Lucky bearings are cheap. Clean, clean and clean. And clean. And if you didn't catch on, clean. White rag in, white rag out. It cannot be understated enough. And no matter what you're told, at the very least use plastigauge to confirm you're in the ball park on your clearances. Anyway, moving on from those apprentice things... Oh, and de-pump your lifters. And another massive don't in amongst all the other big don'ts; do not put assembly lube behind the bearings. Yep, 1st class rookie here making all the mistakes. Argh, time is free and the wife is very forgiving. But leaving all that behind, more positive stuff to report. Got a few bonus jobs done. Posted some of these shots in Puffs thread the other day, please excuse the repeats... Lock wired the Pulsar turbo housing bolts. Bodgied up the Pulsar 1mm oil restrictor fitting into the factory oil feed fitting Red loctite and lock wired the flex bolts. I understand the bolts out backing issue is a combination of power level (say 500+) and what the engine is being turned to (say 6500rpm+) but regardless, got in there first. Early worst case, I feel all sorts of vibrations. Research suggests that at my power level goal I should be ok anyway. 2 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,772 Member For: 16y 5m 14d Gender: Male Location: Melbourne Posted 19/12/22 11:26 AM Share Posted 19/12/22 11:26 AM Good to see you posting the failures as we all make mistakes just like it in our backyarding solid 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,667 Member For: 9y 7m 26d Gender: Male Location: South Australia Posted 14/01/23 10:43 AM Share Posted 14/01/23 10:43 AM Dunno what this guy needs but here for ya mate Link to comment Share on other sites More sharing options...
