XR6 turbo bf radiator leak
XRBOY85
  • New Member
  • Member For: 3y 29d
Hi everyone,
I just found a radiator leak few days ago at the bottom center of the radiator
I removed the fans to get a better idea in where it is coming from and cleaned it all up as was in the channel part on the bottom where  the radiator sits and had a bit of coolant
cleaned it all up and started it and then saw it was coming from the bottom in the center
im guessing I need a new radiator as it is a 15 year old one
what are the recommended radiators to purchase ?? as pwr are to expensive and oem ones a discontinued
its a bf mk11 xr6t zf Making over 400kw
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 9m 19d
ask your local radiator/air-con specialist if it's repairable... otherwise get one from a wrecker if you don't want to spend money with pwr etc.
