ZF Trans Rebuild Adelaide
MUZZA07
  • New Member
  • Member For: 2y 7m 29d
Hi all,
First post so here goes....
Have a BF 2007 XR6 Turbo ute been having trans issue with ZF 6 speed.
Have had trouble with changing from 1-2 shift, car sometimes goes into limp mode after first drive after start up.
Car has just been dropped off to Norwood Automatics at Thebarton. Suspect is solenoid issue.
Will change all rubbers and solenoids and see how she goes.....engine mounts also to be replaced due to engine wanting to move around a bit.....
Will keep everyone posted for results....
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 8m 20d
Yeh mate it happens, Chris is on the level with ZF’s and if it’s anything he can’t manage he will get me to sort it out so you’ll be fine ;)
  • Puff
  • Member For: 10y 22d
Interesting. They knew less about the zf than I did a year ago. In saying that swapping seals and solenoids isn't anything like an actual rebuild.
  • New Member
oh ok cheers for the heads up  Mr K.
The reason for my post is to hopefully help the next person in Adelaide where they can go with this sort of issue.
Cheers!
Will post outcome once car returns home....
  • Puff
Norwood's can do the valve body seals and solenoids no worries. They are a trans and converter shop, what they aren't is a performance zf shop.
In Adelaide, Jeturbo can arrange a build and tune it to suit any amount of power, within reason.
Other places here can build a box but I'd recommend interstate specialists, as they have the runs on the board to support the product.
Chris has come leaps and bounds in the past 6 months, and has a few decent built ZF’s out there now. All have been coupled up with my Tune or he doesn’t warrant them which is fair.
Yeh he’s not done massive spec builds but for 90% of punters he’s stuff will be well suited and over time will only get better
Correct, I only rate interstate builds with the highest regard ;)
