Dat111 Member 30 Member For: 2y 8m 28d Posted 26/09/22 07:24 AM Share Posted 26/09/22 07:24 AM hey guys!! hopefully somebody can tell me, when the 3576 starts to build boost an then it runs out of steam) I cant really find much on the internet. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,199 Member For: 16y 9m 27d Gender: Male Location: Melbourne Posted 26/09/22 07:26 AM Share Posted 26/09/22 07:26 AM it depends entirely on two things: 1. Your mechanical setup with regard to boost control 2. Your tune etc. Any dyno sheet showing "boost" will show it as you desire. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,099 Member For: 10y 8d Gender: Male Location: South Australia Posted 26/09/22 08:13 AM Share Posted 26/09/22 08:13 AM 47 minutes ago, Dat111 said: I cant really find much on the internet. Did you use the search bar? I typed in 3576 and this was on the first page On 22/12/2021 at 5:02 PM, JETURBO said: Hey mate, sorry been pretty busy but I’m here now so I’ll address a few areas to help you First up as I’ve told you before without any negativity but DynaPack Dyno’s read exceptionally high, always have, always will due to their retarder systems. That’s fine as long as you start on one and measure each gain throughout your journey on the same one to see the real number difference which is correct… it’s just the outright numbers never align anywhere close to other brand Dyno’s which can be pretty close to each other! Next up so you can see where I was going on the below tunes I’ll explain this for anyone who doesn’t know …. A factory FG ZF tailshaft can and definitely will snap even on the Dyno when torque is generated at a point past what the shaft can take… this figure is not hard and fast but I know it’s capable of 8psi steady state but not typically more than 10psi ( use stalling up at the lights as the example here ) Next is the factory FG ZF flexplate has a weakness attributed to the factory x6 bolts that secure it to the crank shaft to “walk” loose with torsional rigidity loss at around 380rwkw or 18psi… the harder and faster ( or more aggressive ) the tune is the quicker this will happen and you’ll see why I stop where I stop for these reasons So your 380 ish RWKW @ 14psi is probably closer to 340rwkw honestly. Here is a FG F6 sedan I’ve tuned with the factory GT3582 onboard and typical mods that you have but 18psi up it’s arse on 98 fuel. This vehicle didn’t have an aftermarket market tailshaft or Flex plate so this was as hard and fast as I felt comfortable ramping in the boost. Replace the tailshaft and if I pumped in another 1-1.5psi it would of clipped 400+rwkw on 98 which is about all the GT3582 has as an efficiency peak flow map (19-19.5psi ) and as you can see from the below this tune came out beautifully, all the right curves in the right places Now here are two FG Turbo ZF sedans with Genuine Garrett GTX G2 3576’s on board T3/5bolt/1.06 housings with Genuine Garrett 0.60 comp covers This one was stock Tail shaft / stock Flex plate second one had Carbon fibre tailshaft / stock Flex plate Both have typical mods as you, both on 98 fuel All run in 4th gear etc etc This one stock shaft/flex plate What you can see is if the tailshaft is addressed you can put in a bit more sooner, if you have a Flexplate upgrade ontop I could of pegged a nice 20psi for instance and been into the 400rwkw zone without a doubt on 98 fuel. My honesty thoughts from tuning a large variety of FG’s with different turbos is the fact that yes the GTX of any series (76/82) is vastly superior to the GT The GTX G2 76 I would class the ultimate street turbo matched up to a ZF vehicle for response…. But… up around 400rwkw with the rate of aggressiveness the GTX G2 3576 can deliver on full send ramp in boost will and does destroy the driveline in a faster more obvious manner than say the GT series or GTX G2 3582 can. Some food for thought here…. Bang in a tailshaft, flex plate, HD half shafts and a GTX G2 3576 vehicle can be electric fast too a point where the input shaft start’s hating life next. This is just something we don’t flog out at this rate with other turbos in this manner unless being intentionally abused, the 76 just has more sooner which makes for a fun turbo. I’ve seen many workshops pump out over 400rwkw on the G2 76 and upwards of 450rwkw on E85 !! Assuming you have a full built driveline this turbo can walk in 10 second 1/4 mile passes as we did back with the Gen 1 GTX3576’s Out of the GTX G2 3576 & 82 I suggest customers go for the 82 if they’re more budget minded as we can make factory driveline parts last longer than 76 punters as the 76 is a savage beast on 100% ! And typically can deliver higher numbers on the 82 which 90% of punters want ( big Dyno sheet ) TLDR; GTX G2 3576 - Aggressive tyre fryer GTX G2 3582 - Big numbers on the Dyno Cheers Link to comment Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 5m 2d Posted 26/09/22 05:27 PM Share Posted 26/09/22 05:27 PM 450rwkw on E85 from the baby 3576 turbo?That's more than just a happy dyno. That's a broken dyno! Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 6d Gender: Male Location: Adelaide Posted 26/09/22 09:31 PM Share Posted 26/09/22 09:31 PM Clearly you struggle to read as well as use simple search functions GTX G2 ———— 3576 not GT3576 …. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,099 Member For: 10y 8d Gender: Male Location: South Australia Posted 27/09/22 01:21 AM Share Posted 27/09/22 01:21 AM (edited) 4 hours ago, JETURBO said: Clearly you struggle to read as well as use simple search functions I thought I did pretty good really Thread title says "3576 torque curve", first post describes turbo as "the 3576" and I searched the term, "3576". #muppetshow Edited 27/09/22 01:46 AM by Puffwagon gotta have a space after a comma Link to comment Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 5m 2d Posted 27/09/22 01:29 AM Share Posted 27/09/22 01:29 AM 3 hours ago, JETURBO said: Clearly you struggle to read as well as use simple search functions GTX G2 ———— 3576 not GT3576 …. Where did you get GTX G2 from? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 6d Gender: Male Location: Adelaide Posted 27/09/22 10:14 AM Share Posted 27/09/22 10:14 AM Not you Nath old mate…. Reads link and adds 1+1 and got 450 out of GT Dherrrrrrrrrrrrrrrhhhhhhhppppppp Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,099 Member For: 10y 8d Gender: Male Location: South Australia Posted 27/09/22 11:11 AM Share Posted 27/09/22 11:11 AM Ah ok, I thought it was a bit odd...thought you might have forgotten to prefill your oil filter this morning or something Link to comment Share on other sites More sharing options...
