Engine light and fault codes after tune
Shagsalot
  • Member For: 2y 5m 4d
G'day,
Recently had a set of raceworks 980 cc injectors installed ,venom high flow cat and a plaz 700 hp intercooler installed in my fgx turbo .  Car went in for tune on fri  all was good when I  first drove the car , then engine light and codes via torque app with obd scanner.  P0420 and P 1132 ,car idles rough as guts and now I've got bad rollover noise in the tr6060 .
I don't know if I'm game to take it back to them ,isn't it standard to turn off the sensor after the cat when tuned . I got some lame dyno sheet with just the torque and hp . Nothing with afr or boost levels . It was closing time fri when I picked up the car so they were pretty keen to get my cash and get me out the door . On the torque app it's not overboosting ,do you think it's OK to drive or bite the bullet and go to a well known tuner on the nth side of brissy and get it retuned .
 Thanks for being the part of my brain which isnt functioning properly ATM  , I've corrupted my head with to much  research and what ifs  . It's a long time until Mon, no more reading into what it could be. I'll drop it back there Mon cheers
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m 2d
no worries :spoton:
:Welcome2FordXR6t:
Just make sure you're clear with what you want from them, e.g. the dyno sheet with boost/afr & torque/power... and also an explanation for the codes and a solution that's in line with what you originally paid for - a tuned and normally running car.
Thanks mate ,much appreciated.  Ive been lurking in the shadows on here for quite a while ,reading all the great info here  . I usually just use the search but nothing really directly covered what I was looking for because only the tuner can answer it anything else I find is speculation which isnt good for an overthinker like me lol .  thanks again
Yer I've seen a few other dyno sheets with the mods ive had done and a tune and mine don't look right  the way it drops off .He said it was tuned to 12 psi  but havent got that info yet . Will be asking the tuner tomorrow.
When you save,stash cash  and plan for great and get average leaves you feeling a little disappointed.  Lucky I've got my Mrs reminding me I should of just left it alone,like everything I just dont learn by mistakes, she's always right .
Should sort it tomorrow  with them ,they can't fix what they aren't aware of ,who frigging knows ,will let ya know what they have to say cheers
