  • Member For: 4y 11m 28d
So I have a few mods and recently installed a 15 psi turbo smart wastegate and while there I ported the waste gate hole as it had flapper mod but the hole wasnt opened up
car has 1000cc injectors 3.5 inch exhaust 4 inch dump 460 walbro pump, valve springs oil pump gears.
its has a base map mail order sct tune to get it moving so I can take it to dyno
took it for a squirt gave it alot, it boosted to 22 psi quite hard than I realised backed of and cruised home car had a rough idle on way back sounded like it wasnt running on all cyclinders will take it for a run around block tonight see if its still same
https://www.fordxr6turbo.com/forum/topic/96784-what-may-have-i-damaged/
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m
You likely just fatigued your valve springs, based on the symptoms... hopefully no lasting damage.
The "base map mail order sct tune to get it moving" isn't for "gave it alot" type of efforts, that's just asking for trouble...
  • Member For: 10y 4m 12d
  • Gender: Not Telling
Open the oil cap while it's running and see if it's puffing smoke out. If it is then farken farkers farked. If it doesn't do that then you'll likely be in the clear.
While it may have just been a pumped up lifter, there's also a good chance you broke a ring land. If you've got the gear, give it a compression test.
  • Like 2
  • Site Developer
no need to apologise haha I don't mind being wrong... but I'm sure the OP would prefer I wasn't wrong.
  • 2 weeks later...
