Tubofords New Member 14 Member For: 6y 5d Posted 20/08/22 01:22 AM Share Posted 20/08/22 01:22 AM I'm having the overboost problem (and going into limp mode) and am trying to diagnose. I have tried to manually move the wategate lever but it only moves about 10mm. (Trying to move it by pulling it with a hook) How much movement is there on the arm usually? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,175 Member For: 16y 9m 18d Gender: Male Location: Melbourne Posted 20/08/22 01:24 AM Share Posted 20/08/22 01:24 AM that sounds about right Link to comment Share on other sites More sharing options...
Tubofords New Member 14 Member For: 6y 5d Posted 20/08/22 02:53 AM Author Share Posted 20/08/22 02:53 AM Thanks, I'll test it with 7psi of air. Hopefully it's just a leaky hose. If it's the actuator leaking, do you have to remove the turbo to replace the actuator? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,175 Member For: 16y 9m 18d Gender: Male Location: Melbourne Posted 20/08/22 03:04 AM Share Posted 20/08/22 03:04 AM it's a lot easier to get it done with the turbo off but can be done with it on if you have small enough fingers/hands and picks etc to get the force into the right bits for the c-clips etc. Link to comment Share on other sites More sharing options...
Tubofords New Member 14 Member For: 6y 5d Posted 20/08/22 03:19 AM Author Share Posted 20/08/22 03:19 AM ok thanks Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro...tbh ;) 8===} Gold Donating Members 16,077 Member For: 9y 11m 30d Gender: Male Location: South Australia Posted 20/08/22 03:38 AM Share Posted 20/08/22 03:38 AM 33 minutes ago, k31th said: E-clip There ya go Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,175 Member For: 16y 9m 18d Gender: Male Location: Melbourne Posted 20/08/22 03:50 AM Share Posted 20/08/22 03:50 AM those bloody things go flying whether they're C or E clips haha Link to comment Share on other sites More sharing options...
Tubofords New Member 14 Member For: 6y 5d Posted 25/11/22 08:30 AM Author Share Posted 25/11/22 08:30 AM On 20/08/2022 at 11:24 AM, k31th said: that sounds about right I tested the actuator and had to put about 50psi on my air compressor regulator for it to move. I took a video and it moves only about 5mm. Is this right? Link to comment Share on other sites More sharing options...
Puffwagon Trust me bro...tbh ;) 8===} Gold Donating Members 16,077 Member For: 9y 11m 30d Gender: Male Location: South Australia Posted 25/11/22 08:54 AM Share Posted 25/11/22 08:54 AM Haha it might be correct for a 50psi actuator For future reference don't put 50psi into your actuator again. I don't know how much pressure it needs to rupture the diaphragm but it's not something you want to find out on your own car. The amount yours is moving is nowhere near enough. Either something is physically stopping it from moving, or the actuator is farked. Apply a small amount of air to the actuator via a rubber hose so there is no leak in the air feed. If you can hear air hissing from the actuator, it's farked. Link to comment Share on other sites More sharing options...
Tubofords New Member 14 Member For: 6y 5d Posted 25/11/22 09:09 AM Author Share Posted 25/11/22 09:09 AM (edited) 😂 yeah I just kept dialling up the pressure till something moved, but I just had the air spray nozzle jammed in the inlet pipe. (and yes the car is 100% stock) I tried pulling the lever back more with a hook, but it would only move the amount in the video. So I guess I also need to now work out if the actuator is stuck or the actual wastegate. Edited 25/11/22 09:15 AM by Tubofords Link to comment Share on other sites More sharing options...
