R ichard Member 75 Member For: 4y 9d Posted 15/08/22 07:11 AM Share Posted 15/08/22 07:11 AM hay guys looking at getting a 2nd ZF out of a 2009 ge6T 90,xxxkm, guy has a built gearbox but is going in a different direction with his car, atm valve body and convertor are in the car with his built gearbox question is can I use the valve body and convertor from my gearbox or would they be stuffed from the coolant and trans oil mixing? car is going in on thursday for them to pull it apart but pretty sure its stuffed, when I we checked the oil line on the trans cooler it was pretty much all coolant 😒 im thinking it might be cheaper to buy the 2nd hand ZF ( 1200 nzd without the valve body and convertor or 1600 nzd with them ( would have to wait 2 weeks for him to remove them from car ) than for them to muck around pulling part mine and doing flushes etc is there anything else I should be aware of? sorry if they are dumb questions, any feedback is welcome Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,298 Member For: 16y 11m Gender: Male Location: Melbourne Posted 15/08/22 07:15 AM Share Posted 15/08/22 07:15 AM You can't know for sure if your valve body or TC are stuffed as well until they are inspected. Just wait for advice from the transmission shop that's pulling it out as to how much you have to replace. That $1200NZD was for a built box? seems too good to be true... so they're two different boxes, I assume? Another stock one is fine if you wish to get it. If you have big power goals just get the whole job from the built one Link to comment Share on other sites More sharing options...
R ichard Member 75 Member For: 4y 9d Posted 15/08/22 07:22 AM Author Share Posted 15/08/22 07:22 AM Sorry 1200nzd is for the 2nd hand stock one Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,298 Member For: 16y 11m Gender: Male Location: Melbourne Posted 15/08/22 07:25 AM Share Posted 15/08/22 07:25 AM All good. Depending on your power goals, go with whichever full package and get rid of your own valvebody/tc/gearbox and replace it all, imho. (a few hundred extra for that peace of mind is worth it) Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 9d Gender: Male Location: South Australia Posted 15/08/22 08:25 AM Share Posted 15/08/22 08:25 AM 1 hour ago, R ichard said: when I we checked the oil line on the trans cooler it was pretty much all coolant Of course it was, you let it sit there assembled for a couple of weeks with a failed trans cooler, the coolant clearly was going to leak into the trans if you left it like that. It still doesn't mean it got into the box and stuffed it when it initially failed, while it was running. There will be water/coolant in the box now but that doesn't matter. What matters is if it got in there when it was running and mixed up a milkshake for you. You still haven't told us if you dropped the oil and if it is clean or milky. This will dictate whether you need a new box or not. So...drop the oil, see what it's like and take it from there. Far out man To save further replies, if your oil is farked then the TC as well as the entire box will need fixing, including the valve body. You may as well swap the lot unless you're going to get a rebuilt box with a rebuilt converter. #woosah Link to comment Share on other sites More sharing options...
R ichard Member 75 Member For: 4y 9d Posted 20/08/22 04:31 AM Author Share Posted 20/08/22 04:31 AM Yeah lots of things I could of done better, got the car back, they flushed everything replaced trans cooler, and car drives amazing, gear changes feel smoother than before, looks like I got lucky Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 9d Gender: Male Location: South Australia Posted 20/08/22 04:46 AM Share Posted 20/08/22 04:46 AM 11 minutes ago, R ichard said: looks like I got lucky Looks like it. Keep an eye on your temp gauge for a while, as the radiator may still decide to not work properly after it got filled with oil. Link to comment Share on other sites More sharing options...
R ichard Member 75 Member For: 4y 9d Posted 20/08/22 04:50 AM Author Share Posted 20/08/22 04:50 AM Will do, I did flush all the cooling System straight away, was just the trans part I wasn’t confident in, here’s hoping Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,181 Member For: 10y 1m 9d Gender: Male Location: South Australia Posted 20/08/22 05:13 AM Share Posted 20/08/22 05:13 AM You need to flush it with the thermostat out otherwise the cold water will close it and it won't flush properly. I may have mentioned it but you can use clothes detergent to flush it, it works quite well. A fair bit of oil will still collect in the header tank over the next few drives, pretty normal as the block and radiator will have residue. Anyhow sounds like it's under control now so crack a beer and cheers to good luck Link to comment Share on other sites More sharing options...
R ichard Member 75 Member For: 4y 9d Posted 14/09/22 07:08 PM Author Share Posted 14/09/22 07:08 PM looks like I may of not been so lucky, 1st few drives were sweet, gearbox felt better than before, but this morning when I was driving to work the revs were jumping around quite abit, will see how I go after work, just my luck lol Link to comment Share on other sites More sharing options...
