hjtrbo Bronze Donating Members 320 Member For: 13y 9m 19d Posted 22/07/22 02:58 AM Share Posted 22/07/22 02:58 AM Hey you lot. Doing it backwards. Just pull the bastard apart and order sh*t later. Pulling the timing cover off to fix the stupid front lower oil leaks. Just wondering if I could get a hand with the parts list? Water pump Timing chain kit Decent rtv Front timing cover seal Thread sealer ? Thanks legends. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,827 Member For: 9y 9m 9d Gender: Male Location: South Australia Posted 22/07/22 04:29 AM Share Posted 22/07/22 04:29 AM Some timing covers have rubber seals and some just use silicone. Some sump seals are one piece and some are two piece. If the balancer seal in the timing cover is leaking then replace that while it's off. Work out what type of timing cover and sump you have then you can order stuff for it. You'll need the ultra black either way. I use Loxeal 58-11 for any threads that need to be sealed. Bunnings has it and it works very well. If you want to upgrade stuff or just replace stuff then Atomic has a fully hectic timing kit for the Barra. If you think that's overkill, you can get new Nason guides and a heavy duty chain to save a bit of money there. I've had no dramas with the GMB water pump. Goleby's sell all that sh*t. 1 Link to comment Share on other sites More sharing options...
hjtrbo Bronze Donating Members 320 Member For: 13y 9m 19d Posted 24/07/22 07:47 AM Author Share Posted 24/07/22 07:47 AM Hey @Puffwagon and company. I'm going to do the head studs and oil pump gears / backing plate while its apart as I want to lean on the tune a bit harder on e85. Targeting mid 400's and she's my daily driver. Still has the genuine ford head gasket in there and I was thinking about being the poor man that I am and just doing the old 1 stud at a time head bolt changeover. What do you reckon about the poor mans head bolt change? Compared to you I don't know f#ck all about cars, just like getting in and having a go. There is a small crowd out there that spruik the method and report good success. I know its not ideal vs lifting the head and pulling the block out for a skim, but if I can get away with it, then fark it, why not right??? This is what I've got for the parts list (Golebys): ARP head studs BA/BF/FG 6 cylinder Barra Turbo 252-4302 $549 Barra 6cyl engine GMB water pump Turbo and non Turbo (GWF-106AP) $55 BA BF FG Ford Falcon Barra Timing gasket and seal set (TCS48) $55 GRP Engineering BA, BF and FG 6 Cylinder tappet cover gasket set $90 BA BF and FG Oil Pan gasket and Seal Set $50 Atomic Barra Heavy Duty Timing Chain Kit (306620-K-S) $693 Atomic Oil Pump End Plate (306753) $308 Atomic Billet Oil Pump Gears (306750) $475 $2,275 incl. gst + delivery Link to comment Share on other sites More sharing options...
hjtrbo Bronze Donating Members 320 Member For: 13y 9m 19d Posted 26/07/22 11:17 PM Author Share Posted 26/07/22 11:17 PM Home made removal tool. Yeah, problem found. 1 Link to comment Share on other sites More sharing options...
hjtrbo Bronze Donating Members 320 Member For: 13y 9m 19d Posted 27/07/22 05:49 AM Author Share Posted 27/07/22 05:49 AM Hmm, I'm presuming this is bad https://1drv.ms/u/s!Atuxgi8rpo3Vmc9WdmNakpt9oSIDtg?e=5ySbth https://1drv.ms/u/s!Atuxgi8rpo3Vmc9VluR63eruBj6f_A?e=d48Oam https://1drv.ms/u/s!Atuxgi8rpo3Vmc9UObl7Ho9prg4BDA?e=zb6UOW Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,827 Member For: 9y 9m 9d Gender: Male Location: South Australia Posted 27/07/22 06:42 AM Share Posted 27/07/22 06:42 AM Not ideal. You're replacing the timing chain guide anyway so it doesn't matter. The roller in the rocker doesn't matter if it's just got lines in it but the cam looks pretty stuffed. If you're doing head studs you'll have the cams out anyway so just fit a new set while you're at it. Link to comment Share on other sites More sharing options...
hjtrbo Bronze Donating Members 320 Member For: 13y 9m 19d Posted 27/07/22 06:45 AM Author Share Posted 27/07/22 06:45 AM Thanks Puffwagon. FYI I can feel those lines in the roller with my finger nail. Do I just try and polish out the high spots or buy a new set or just leave them like you said. Thanks mate. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,827 Member For: 9y 9m 9d Gender: Male Location: South Australia Posted 27/07/22 07:02 AM Share Posted 27/07/22 07:02 AM How many are stuffed? I've got several engines worth here, so can find a few good ones for you. An option is to buy an FG na engine and just take the cams and rockers out of it. Link to comment Share on other sites More sharing options...
hjtrbo Bronze Donating Members 320 Member For: 13y 9m 19d Posted 27/07/22 07:05 AM Author Share Posted 27/07/22 07:05 AM Thanks for the offer. Leave it with me, will pull the cams tomorrow and have a decent look at them all. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,827 Member For: 9y 9m 9d Gender: Male Location: South Australia Posted 27/07/22 07:10 AM Share Posted 27/07/22 07:10 AM No worries. Link to comment Share on other sites More sharing options...
