  • Member For: 4y 1m 19d
hay guys, I have a 2009 xr6 turbo,
over the last 2 weeks I some times get a fault on dash ''transmission not in park'' when its in park
when it does happen the car is off and only happens when I open the drivers side door, doesnt happen every time I open the door   ( maybe twice  a week )
any one know what would cause this?
I only just did a antz Turbo Side Intake & Passenger Battery Relocation kit, then week after it started to happen, would a bad earth cause weird faults?
 battery is good
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 20d
Yes clean up that Earth contact point and potentially time for a new battery mate despite what it test up as especially if it’s an “Century” battery ;)
  • 2 weeks later...
Cleaned up the Earth connections and changed the battery out no change, it’s weird if I unlock the car and then open the door it doesn’t happen but if I leave the car unlocked for 10/20 minutes and then open the door it comes up with it with fault
  • 1 year later...
