XR6T BATTERY VOLTAGE DROP UP AND DOWN ONLY ON IDLE
XRBOY85
  • New Member
  • Member For: 2y 11m 19d
Hi everybody
I have a bf xr6 turbo 6 speed and my battery voltage since I bought it on idle or coming to a stop in any gear will say go from 14.1v to 13.4/13.5v and then back up again
if I start driving it will go back to 14.1 and stay there as long as I do not slow down to a stop and when I do slow down coming to stop at the lights it will just stay at around 13.9 and 5 seconds later will drop to 13.4 and then again back up to 13.9/14.1 and same drop again until I start driving and then stabilize
it has a new alternator and new motorcraft battery from ford and the earth strapping seems ok
I have tested the voltage also directly from the battery on idle and not on my volts gauge and does the same thing every 5 seconds goes to 13.8/13.9 to 13.3/13.4
any ideas or anyone had a similar issue and fixed it
any help would be great or info
thanks
  • Puff
  • Member For: 9y 10m 20d
I just pulled this out of my ass so take it with a grain of salt :focus:
Sounds like a smart alternator doing it's thing. Here's a pic of a Ford smart alternator (not necessarily an aussie falcon version) that demonstrates the alternator waveform with the engine at idle and the alternator at light load, then another at idle with moderate load. This is where I got the info from.
Blue= Alternator output current
Red= Alternator feedback signal
Green= Alternator command signal from PCM.
