F6 Poser New Member 2 Member For: 2y 11m 4d Posted 05/06/22 12:34 PM Share Posted 05/06/22 12:34 PM Hi I’m trying to squeeze as much power as I can out of my fg xr6 I want to get a lightened flywheel for it and am not having any luck finding one for an na but I have found some turbo ones and am wondering if they will still bolt up to the na motor with the na tr6060 box with the turbo clutch and flywheel Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/96704-can-i-use-a-fg-xr6t-lightened-flywheel-and-clutch-on-my-na-fg-xr6/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,488 Member For: 17y 29d Gender: Male Location: Melbourne Posted 05/06/22 11:27 PM Share Posted 05/06/22 11:27 PM Yes, it will work as the input shaft is the same OD and spline across the N/A and Turbo gearboxes (23mm outer diameter, 26 spline), just the size of the clutch is bigger on the turbo (~280mm on the turbo as compared to the ~256mm N/A one). So as long as you use the bigger flywheel for the turbo along with the turbo clutch, it'll work. Link to comment https://www.fordxr6turbo.com/forum/topic/96704-can-i-use-a-fg-xr6t-lightened-flywheel-and-clutch-on-my-na-fg-xr6/#findComment-1712585 Share on other sites More sharing options...
eff xr6t Member 569 Member For: 11y 7m 9d Posted 05/06/22 11:44 PM Share Posted 05/06/22 11:44 PM No mate it wont work. You need the matching turbo bellhousing to make it work. Your other option is to get one of the modified 280mm clutch pressure plates and flywheels from mal wood, direct clutch, npc as they have been machined down to fit in the Na fg/ba/bf size bellhousing. Link to comment https://www.fordxr6turbo.com/forum/topic/96704-can-i-use-a-fg-xr6t-lightened-flywheel-and-clutch-on-my-na-fg-xr6/#findComment-1712589 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,488 Member For: 17y 29d Gender: Male Location: Melbourne Posted 05/06/22 11:45 PM Share Posted 05/06/22 11:45 PM ahh the bloody bellhousing, I always forget it's smaller on the N/A gearbox... my bad Link to comment https://www.fordxr6turbo.com/forum/topic/96704-can-i-use-a-fg-xr6t-lightened-flywheel-and-clutch-on-my-na-fg-xr6/#findComment-1712590 Share on other sites More sharing options...
F6 Poser New Member 2 Member For: 2y 11m 4d Posted 06/06/22 03:20 AM Author Share Posted 06/06/22 03:20 AM Thanks for the reply guys really appreciate it heaps Link to comment https://www.fordxr6turbo.com/forum/topic/96704-can-i-use-a-fg-xr6t-lightened-flywheel-and-clutch-on-my-na-fg-xr6/#findComment-1712593 Share on other sites More sharing options...
