  • Member For: 3y 6m 11d
hello all. ive recently noticed my zf6 transmission from my bf mk1 turbo knocking/rattling when put into reverse. not sure what problem this is, the car is warmed up pretty well however it is cold outside still but doubt this comes into play. anyone know what it could be? cheers
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 11d
Sounds like your flex plate has come loose mate, stop driving it and get it seen to asap !
to confirm if it’s a flexplate that has come loose do this for a very short period to test then switch off immediately
Start car
put into reverse
wait for rattle/knock to appear
put foot hard on brake
put foot on accelerator a touch and bring some load onto the transmission whilst maintaining the foot brake hard
if the noise seems to disappear in this “Loading” state it’s 100% a loose flex plate and switch off and get it towed to a workshop for rectification works
continue to run the engine can lead to excessive crank shaft to flex plate mating surfaces wear which can mean a new crank shaft and that’s a rebuild of the engine basically ;)
Let us know how you go
Edited by JETURBO
by chance it doesnt keep knocking when putting some load on the transmission, what could that potentially mean?
either way, the transmission making this noise is practically I <3 Bananased right?
  • Puff
  • Member For: 10y 2m 13d
Read his post again carefully. He said the noise will disappear with load if it is the flex plate.
  • Puff
Does it keep knocking?
At any rate the trans will be fine if the flex plate is stuffed. The trans will have to be pulled out and the flex plate replaced.
  • Puff
"If" it is loose it might have jammed itself hence no noise for a while. Maybe it's like my lawnmower and magically fixed itself! Yeah nah, jk, that didn't happen.
This would be my next bit of advice.
Well you can remove the starter motor and physically get your fingers on it and see if it wiggles before removing converter bolts
