fg xr6 turbo ute conversion to fg na xr6 sedan
  • New Member
  • Member For: 3y 1m 15d
hey there
I had a crashed fg turbo ute and decided to swap out all the parts over to the na fg sedan. motor, ecu, gearbox, new lsd diff because ute diff is solid axel, tailshaft and cv shafts. however there is no communication between the pcm and the rest of the car and our guess is because the sedan previously had a 5 speed auto and we put the zf6 in we need to swap the body looms from the sedan's to the ute because the ute was a 6 speed. after doing that will the car be able to atleast communicate let alone start?
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 10m 10d
Just make sure all electrical modules from the donor the car are also included. Mostly the BEM (Body Electronics Module) which is a flat sort of rectangle thing piece of plastic with a lot of wires going into it with multiple plugs.
  • New Member
thanks for that mate. also a quick follow up do you reckon the icc also needs to be swapped? also regarding the body harnesses are they the same in both the sedans and the utes? currently stuck on the wiring issue and kinda split minded if I should continue with this.
  • Site Developer
wiring is obviously more in the sedan, but still, just keep the loom from the sedan and all the modules from the ute.
