BloodBAute New Member 12 Member For: 3y 2m 20d Posted 02/03/22 09:54 PM Share Posted 02/03/22 09:54 PM G'day. Can anyone tell me if it's possible to identify whether a T56 is from a turbo or naturally aspirated via the ID tag on the gearbox? I have a 6 speed in my "originally 5 speed" BA and am unsure. Tag reads as: TUET4928 AE J3042 3R23-7003-EB 00550 Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/96626-t56-identification/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,493 Member For: 17y 1m 4d Gender: Male Location: Melbourne Posted 02/03/22 10:20 PM Share Posted 02/03/22 10:20 PM well, good news is "3R23" is an identifier for BA. "7003" is seemingly on all Ford AU Tremec's not sure what "EB" is in that code... it was "CB" for the Tremec T5 (your original gearbox), so that makes me think it's likely just the next model up, which was the original T56 6-speed replacement for the T5 which was too weak for the turbo variants. The other bit doesn't make any sense to me. Got all my information from this post (the irony of it being on an Australia Volvo site haha, but it's definitely quality information). https://ozvolvo.org/discussion/comment/62223/#Comment_62223 Might be worth giving Mal Wood a call to confirm the details (and of course return here to let us know what you find out). Link to comment https://www.fordxr6turbo.com/forum/topic/96626-t56-identification/#findComment-1710858 Share on other sites More sharing options...
BloodBAute New Member 12 Member For: 3y 2m 20d Posted 02/03/22 11:13 PM Author Share Posted 02/03/22 11:13 PM Thanks for that @k31th. I think you're right in that it's just the 6 speed from the BA series 2. As far as I can find the input shafts for both the NA and turbo gearbox are the same, I need a new clutch and wanted to make sure I wasn't ordering the wrong one. I managed to find a Tremec Service Bulletin which has a description helping to decipher the tag. Seems the "EB" is the revision level and the rest is part numbers and manufacturing dates etc. Although it still doesn't help me to work out exactly which gearbox I have it may be useful and help others as well. I'll attach it once I figure out how. To find the Service Bulletin go to https://www.tremec.com/literatura.php and search for trtb05007 Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/96626-t56-identification/#findComment-1710863 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,493 Member For: 17y 1m 4d Gender: Male Location: Melbourne Posted 02/03/22 11:38 PM Share Posted 02/03/22 11:38 PM that TSB is quite helpful: https://www.tremec.com/anexos/TRTB05007_147.pdf as per that PDF: "TUET" is T56/TR6060 for sure. Definitely the 6-speed. "4948" is the remainder of the Tremec-specific part-number. "00550" is your serial number of your Tremec hardware. "AE" is the "Revision Level" (something Tremec could clarify specifically) J3042 is broken down as a manufacturing date; "J"=September, "30"=30th day, "4"=2004, "2"=2nd shift. "3R23-7003-EB" is the "Customer Part Number", broken down as above. The "EB" is the only unknown part here, but seemingly irrelevant now that the rest is clarified. Link to comment https://www.fordxr6turbo.com/forum/topic/96626-t56-identification/#findComment-1710865 Share on other sites More sharing options...
BloodBAute New Member 12 Member For: 3y 2m 20d Posted 03/03/22 12:00 AM Author Share Posted 03/03/22 12:00 AM Ah yes the AE is the revision level not the EB. My bad. Main thing for me is I know it's 26 spline input shaft. Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/96626-t56-identification/#findComment-1710870 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,493 Member For: 17y 1m 4d Gender: Male Location: Melbourne Posted 03/03/22 12:07 AM Share Posted 03/03/22 12:07 AM yeah, that'll be enough information for you to order a clutch; T56 and 26 spline. Link to comment https://www.fordxr6turbo.com/forum/topic/96626-t56-identification/#findComment-1710871 Share on other sites More sharing options...
BloodBAute New Member 12 Member For: 3y 2m 20d Posted 06/03/22 09:47 AM Author Share Posted 06/03/22 09:47 AM Just as a follow up to this, on another forum someone was able to give further info on the revision numbers which confirm my box is a BA NA box. "you've decoded the part number right so far, first part is date code. 3R23 2003 (BA), a 5R29 is 2005 BF. 7003 manual trans. the E is the subtype, and B minor revision of that type. the 6-speeds should be... G N/A 6's H or K Turbo 6's F or J V8's A T5 n/a 6's in utes B T5 n/a 6's with ABS in utes C T5 turbo 6's in utes D was the TR3650 for V8's E T5 n/a 6's in sedans." Link to comment https://www.fordxr6turbo.com/forum/topic/96626-t56-identification/#findComment-1710931 Share on other sites More sharing options...
