  • Member For: 5y 1m 10d
So I bought a 2014 xr6 turbo a month ago and for a while I had a rattling noise from the engine bay on idle and have just realised it also rattles when at low rpm (cant hear much at mid-high rpm due to the exhaust). I can really only hear the rattling noise when sitting in the drivers seat with the window down, I just had the idler pulley, pulley tensioner and drive belt replaced because I thought that was the issue but its still there. Any help would be appreciated as it doesn't sound good at all.
Mods (all done by previous owner):
1000cc injectors
3.5inch turbo back exhaust with 4 inch cat and mid muffler delete
fuel pump (unsure what fuel pump)
1000hp rated intercooler
battery relocation/turbo side intake
braided turbo oil line
NPC twin plate clutch 1000hp rated
tuned to 327rwkw
https://www.fordxr6turbo.com/forum/topic/96620-rattling-noise-in-engine-bay/
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 7d
it says "NPC twin plate clutch" ... it's a manual...
that being said, all twin plate clutches rattle around a bit when they're in neutral...
Does it happen when you're sitting still and changing the revs? or does it only happen when you're rolling/driving?
  • 1 month later...
