  • Member For: 4y 3m 18d
hi guys last night I'm was driving in town and had to hard swerve to avoid hitting a cat on the road, 10 sec after that I lost power steering so drove home with was only a min away, just as I got home the temp gauge hit max and there was a battery error on screen which im getting is because the belt came off,
reckon a new belt will be all that's needed or do you think I might of damaged the engine or water pump etc, in hind sight I should of pulled over when it happen, will get a new belt tomorrow and get a mate to help me change it but just thought id ask you guys on your opinion
https://www.fordxr6turbo.com/forum/topic/96603-fg-drive-belt/
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 9d
Don't worry too much, just replace the belt and see if it behaves normally afterwards. A minute of driving won't overheat your car considerably or damage it enough to cause lasting damage by overheating.
  • Member For: 6y 9m 15d
Just replace the belt? Did you look at the picture?
Water pump is shagged.
  • Site Developer
Expand
well you can't tell from a photo for sure whether a pulley is stuffed (even though it looks like it in that photo). Just replace the relevant pulleys along with the belt if they are making noises or feel "grindy" when you turn them by hand. Easy to do while the belt is off.
  • Site Developer
  On 07/02/2022 at 6:14 AM, Puffwagon said:
Look at the water pump @k31th
Expand
yeah, I can see it... the pulley looks rusty/wonky for the water pump... but you can't see the internals of it to see if it's actually broken, but it would explain the over-heating issue, but surely the OP would have noticed the heat issues before it forced the belt to fail haha
  • Member For: 10y 4m 21d
  • Gender: Not Telling
Water pump failed, belt got thrown, car overheated. All of that happened within a couple of minutes.
You might get away with pressing a new steel pulley onto it, but for the price of a new pump you wouldn't bother.
Edit: Yes the actual pump internals might still be ok.
Edited by Puffwagon
Just cos
  On 07/02/2022 at 6:17 AM, R ichard said:
this the correct water pump for a FG xr6 turbo?
Expand
I used this in my 700+kw build and it was fine. Only cost $55 too!
https://www.golebysparts.com.au/products/barra-6cyl-engine-gmb-water-pump-turbo-and-non-turbo-w2079p?_pos=22&_sid=e1f297a9c&_ss=r
