XRBOY85 New Member 23 Member For: 2y 8m 20d Posted 06/02/22 06:18 AM Share Posted 06/02/22 06:18 AM Hi everyone I have bf xr6 turbo and have just spotted out a oil leak coming from in between the heat shield and the power steering Was abit of a trail all the way down to sump when I had purchased the car few month ago have just cleaned it all up and 2 days later of driving now its coming from where I just mentioned Here is a picture Timing case maybe ? It is engine oil and not power steering oil Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,652 Member For: 9y 7m 21d Gender: Male Location: South Australia Posted 06/02/22 06:21 AM Share Posted 06/02/22 06:21 AM Clean it properly, go for a drive around the block for 5 minutes then see where it's leaking from. Two days of driving is too long to pinpoint a leak. Link to comment Share on other sites More sharing options...
XRBOY85 New Member 23 Member For: 2y 8m 20d Posted 06/02/22 06:29 AM Author Share Posted 06/02/22 06:29 AM I did clean it properly all the way to bottom I ment two days of driving as in its been two days of checking it for two days from after cleaning when I cleaned it all dry from top to bottom degreased, air compessor I took it for a 10 minute drive and nothing and then 4 to 5 hours later of letting it sit it started to slowly see a little wet patch up top where I mentioned and now a little more the next day being now in that pic and has not yet trickled down to the block I have taken off the the heat shield near the power steering and its in the corner but hard to see Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,652 Member For: 9y 7m 21d Gender: Male Location: South Australia Posted 06/02/22 06:37 AM Share Posted 06/02/22 06:37 AM Yeah you can't see frig all in the pic. The things that can show a leak in that area are; cam solenoid seals, rocker cover, timing cover, power steering and head. Air turbulence does funny tings to oil leaks so bear that in mind. All you can do is what I said to start with. If it appears and you can't pinpoint it then you have to start again and make sure you catch it as soon as it appears. Unfortunately there is no easy way to do it and this is what any mechanic shop will be doing. Link to comment Share on other sites More sharing options...
XRBOY85 New Member 23 Member For: 2y 8m 20d Posted 06/02/22 08:40 AM Author Share Posted 06/02/22 08:40 AM I just undone and pulled back the heat shield and clearly shows where it is or starts in the video clip Think around gasket ? Not sure Any ideas Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,652 Member For: 9y 7m 21d Gender: Male Location: South Australia Posted 06/02/22 08:57 AM Share Posted 06/02/22 08:57 AM Alright we can see that a bit better. Looks to be timing cover or head. If the car has been tuned and sent for a 6 then it could be the head but more then likely is just the timing cover. Maybe you can clean it off again, run it in the driveway with the heat shield off and watch it? Might have to rev it a few times to get the oil splashing around. Don't rule out it being anything else but that's what I'm seeing. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,758 Member For: 16y 5m 10d Gender: Male Location: Melbourne Posted 06/02/22 11:31 AM Share Posted 06/02/22 11:31 AM it's almost always the timing cover and looks like it is in this case, too. Link to comment Share on other sites More sharing options...
bjc Donating Members 2,821 Member For: 21y 16d Gender: Male Location: Townsville Posted 08/02/22 02:41 PM Share Posted 08/02/22 02:41 PM It'll be the timing cover and leaking from where the rocker cover meets it on the side (where they goop the corners). Mine did the same on a highway cruise when the catch can lines I had plumbed up were kinked so I'm guessing it blew a pooper valve! It also coincidentally misfired badly while overtaking a few times but I can't really say if the two are related although if I'm sticking to the anus theme then we all know how much wind hurts when you don't let it out... Link to comment Share on other sites More sharing options...
