Sonia New Member 5 Member For: 3y 4m 8d Posted 05/02/22 11:23 AM Share Posted 05/02/22 11:23 AM My car broke down after turning it off, the reds come on but there's no kick. Can someone please help me as I'm told it may be the bcm but I'm not sure. I've had the key and ignition replaced and paired by Ford to no avail. This is my pride and joy and I really want to get her fixed, as ppl say they've had some similar problems and the cars never ran again Link to comment https://www.fordxr6turbo.com/forum/topic/96598-my-2004-ford-falcon-xr6-wont-start-after-turning-it-off/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,544 Member For: 17y 2m 4d Gender: Male Location: Melbourne Posted 05/02/22 01:21 PM Share Posted 05/02/22 01:21 PM Sounds like a dead battery/alternator combination. Link to comment https://www.fordxr6turbo.com/forum/topic/96598-my-2004-ford-falcon-xr6-wont-start-after-turning-it-off/#findComment-1710398 Share on other sites More sharing options...
Sonia New Member 5 Member For: 3y 4m 8d Posted 06/02/22 04:44 AM Author Share Posted 06/02/22 04:44 AM Really far out. The trained monkeys here at Lithgow ford paired the new key and ignition and said they couldn't help me but if they were to try I'd be up the creek. What do you think it might be as I just brought a $300 century battery and the alternator was running fine. It's just like the anti theft/ immobiliser has engaged. There is no communication from key to starter what do you think my problem might be?. Link to comment https://www.fordxr6turbo.com/forum/topic/96598-my-2004-ford-falcon-xr6-wont-start-after-turning-it-off/#findComment-1710403 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,544 Member For: 17y 2m 4d Gender: Male Location: Melbourne Posted 06/02/22 05:03 AM Share Posted 06/02/22 05:03 AM well if your battery is dead (you can easily test that with a multi-meter; look up how specifically online wherever) and then if it is, it's likely your alternator or relevant charging circuit is no good. Link to comment https://www.fordxr6turbo.com/forum/topic/96598-my-2004-ford-falcon-xr6-wont-start-after-turning-it-off/#findComment-1710404 Share on other sites More sharing options...
Sonia New Member 5 Member For: 3y 4m 8d Posted 06/02/22 07:28 AM Author Share Posted 06/02/22 07:28 AM Definitely got power in it.. I just can't work it out NRMA have tested the battery,starter motor,relays and alternater. At first I thought it was key or key reader so I put into mechanics and got new ignition and reader they sent the car to ford to pair and the problem is the same. do you think it might be the bcm?or can think of anything else it may be? All I did was turn the car off and all the security, antitheft came on,and the stereo asked me for a code which it has never before Link to comment https://www.fordxr6turbo.com/forum/topic/96598-my-2004-ford-falcon-xr6-wont-start-after-turning-it-off/#findComment-1710410 Share on other sites More sharing options...
Sonia New Member 5 Member For: 3y 4m 8d Posted 06/02/22 10:42 AM Author Share Posted 06/02/22 10:42 AM Would you know by any chance, Need to know if I change my bcm, ignition and key, will I have to change the one under the bonnet aswell? Link to comment https://www.fordxr6turbo.com/forum/topic/96598-my-2004-ford-falcon-xr6-wont-start-after-turning-it-off/#findComment-1710417 Share on other sites More sharing options...
