Nikola. New Member 8 Member For: 5y 5m 7d Posted 30/01/22 08:34 AM Share Posted 30/01/22 08:34 AM Hey guys I have been looking at installing a single din headunit using the fascia from stingray security https://www.stingraycar.com.au/product/fg-fgx-aftermaket-single-din-fascia/ . I want to know how people have done the wiring. Is there a harness I can buy or do I have to splice into the icc harness. Link to comment https://www.fordxr6turbo.com/forum/topic/96585-fg-falcon-single-din-wiring/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,568 Member For: 17y 2m 14d Gender: Male Location: Melbourne Posted 30/01/22 09:21 AM Share Posted 30/01/22 09:21 AM Depends what sort of functionality you want out of it. Do you want to just have your standard ICC do no audio and have your audio straight out of the HU or do you want the standard ICC to go into the aux-input or something of the HU and then go out to amps/speakers? Link to comment https://www.fordxr6turbo.com/forum/topic/96585-fg-falcon-single-din-wiring/#findComment-1710281 Share on other sites More sharing options...
Nikola. New Member 8 Member For: 5y 5m 7d Posted 30/01/22 09:31 AM Author Share Posted 30/01/22 09:31 AM I don’t want Audio out of the standard icc. I want the speakers to go straight into the head unit so I can have better sound quality and be able to have rca outputs for amps without a line converter. I’m over using my aux Bluetooth adapter cause the wires are annoying me and the aux port likes to cut out if you touch the cable and I need to mess around with it to make the Audio come back. Link to comment https://www.fordxr6turbo.com/forum/topic/96585-fg-falcon-single-din-wiring/#findComment-1710283 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,568 Member For: 17y 2m 14d Gender: Male Location: Melbourne Posted 30/01/22 09:52 AM Share Posted 30/01/22 09:52 AM OK, then you don't need to tap into the back of the ICC wiring at all. You just run RCA's out of the HU out to an amp, then from the amp back to the wiring in the kick panels and/or behind the glove box, which goes to the speakers in the doors. Some pics and info from an FG-X I did (extremely similar to an FG) (just ignore the part where you go to an LLC, you go from your HU straight to an amp). Then you can replace the speakers in the doors with higher quality ones if you wish (probably wise if you're going to be amplifying the signal out of the HU). All you need for the HU is constant power, earth and accessories which you can get from the 12v source and near the fuse panel for constant. Then you run a remote for your amp if it doesn't have automatic-on functionality and you're done for audio. Link to comment https://www.fordxr6turbo.com/forum/topic/96585-fg-falcon-single-din-wiring/#findComment-1710285 Share on other sites More sharing options...
Nikola. New Member 8 Member For: 5y 5m 7d Posted 30/01/22 10:04 AM Author Share Posted 30/01/22 10:04 AM Thanks for the help mate. Link to comment https://www.fordxr6turbo.com/forum/topic/96585-fg-falcon-single-din-wiring/#findComment-1710286 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,568 Member For: 17y 2m 14d Gender: Male Location: Melbourne Posted 30/01/22 10:07 AM Share Posted 30/01/22 10:07 AM no worries. Let us know when it's installed and hammering along Link to comment https://www.fordxr6turbo.com/forum/topic/96585-fg-falcon-single-din-wiring/#findComment-1710287 Share on other sites More sharing options...
