Slowxr6t Member 560 Member For: 5y 11m 14d Location: New zealand Posted 15/01/22 09:22 AM Share Posted 15/01/22 09:22 AM So Iv just got engine back in and everything hooked back up, well I think everything hooked up after new ati balancer, atomic flexplate, new HD timing chain kit, resealing up motor and hopefully fixing oil leak on the front sump seal. Long story short been very meticulous and careful with all plugs and hooking everything up and went to start motor and dash lights all come on, turn key and nothing, no click click, no starter motor noise, when I turn key radio goes silent but that's it. Anyone got any ideas? Please Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 18d Gender: Male Location: Adelaide Posted 16/01/22 08:52 AM Share Posted 16/01/22 08:52 AM Flat battery !!! Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,862 Member For: 9y 9m 20d Gender: Male Location: South Australia Posted 16/01/22 08:59 AM Share Posted 16/01/22 08:59 AM Might have forgotten the earth strap to the drivers side engine block. Link to comment Share on other sites More sharing options...
Slowxr6t Member 560 Member For: 5y 11m 14d Location: New zealand Posted 16/01/22 10:06 AM Author Share Posted 16/01/22 10:06 AM Nope earth strap is bolted on and had a jump pack on battery to make sure it had some juice. Could it be anything to do with zf loom plug connectivity? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,862 Member For: 9y 9m 20d Gender: Male Location: South Australia Posted 16/01/22 10:15 AM Share Posted 16/01/22 10:15 AM Maybe the starter motor trigger wire is off/loose/dirty connection? 8 minutes ago, Slowxr6t said: Could it be anything to do with zf loom plug connectivity? Unplug it and replug it?! Link to comment Share on other sites More sharing options...
Slowxr6t Member 560 Member For: 5y 11m 14d Location: New zealand Posted 16/01/22 10:31 AM Author Share Posted 16/01/22 10:31 AM The little red wire from the loom with spade terminal that goes onto starter iv taken on and off starter a couple of times, clicks on good, no go. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 15,862 Member For: 9y 9m 20d Gender: Male Location: South Australia Posted 16/01/22 10:46 AM Share Posted 16/01/22 10:46 AM Does it have a 12v signal when you turn the key to start? Link to comment Share on other sites More sharing options...
Slowxr6t Member 560 Member For: 5y 11m 14d Location: New zealand Posted 16/01/22 10:53 AM Author Share Posted 16/01/22 10:53 AM Havnt checked, I'll get sparky to check it out tomorrow Link to comment Share on other sites More sharing options...
Slowxr6t Member 560 Member For: 5y 11m 14d Location: New zealand Posted 16/01/22 08:58 PM Author Share Posted 16/01/22 08:58 PM There's another plug on the side of zf that I have nothing plugged into, is that for diagnostics or something or should I have a plug in that too? Link to comment Share on other sites More sharing options...
Slowxr6t Member 560 Member For: 5y 11m 14d Location: New zealand Posted 17/01/22 02:21 AM Author Share Posted 17/01/22 02:21 AM My auto electrician worked out that zf gear selector was in slightly the wrong place, dash was saying it was in P for park, but trans wasn't. When we put trans in R the engine started. We adjusted the trans selector arm and she's all good now, yaaa. Battery was too flat as well so charging that up too, jump pack didn't have the juice either, thanks @JETURBO and @Puffwagon. 3 Link to comment Share on other sites More sharing options...
