dood1164 New Member 13 Member For: 3y 3m 22d Posted 07/01/22 05:34 AM Share Posted 07/01/22 05:34 AM G'day all, I'm new to the turbo world and am seeking such much needed advice. I own a 2003 ba xr6t and when after purchasing sight unseen (I know don't hate me haha) have discovered my turbo is cooked. I have purchased a GT3582r from turbochargersplus and a new oil feed line as I'm certain that is the cause of the issue. I can't find any info if the boost control will be the same as factory and if once installed will I have to straight away to get it tuned. I am worried about the turbo overboosting and causing me more grief. Any help will be greatly appreciated, Cheers Dylan Link to comment https://www.fordxr6turbo.com/forum/topic/96567-installing-gt3582r-high-flow/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,447 Member For: 17y 19d Gender: Male Location: Melbourne Posted 07/01/22 05:41 AM Share Posted 07/01/22 05:41 AM As long as the turbo is exactly the same specifications (e.g. size and shapes of wheels) then it'll be fine to just run it as-is without a tune. Ask the supplier for the specifications to confirm. If it's got different hardware there's a high likelihood of issues and you'll need a dyno-tune to suit the new turbo. Link to comment https://www.fordxr6turbo.com/forum/topic/96567-installing-gt3582r-high-flow/#findComment-1710031 Share on other sites More sharing options...
dood1164 New Member 13 Member For: 3y 3m 22d Posted 07/01/22 05:46 AM Author Share Posted 07/01/22 05:46 AM Thanks for the reply so fast 😃, how would I be able to find the specifications for the factory turbo? I'll send supplier an email now for the specs 😀 Link to comment https://www.fordxr6turbo.com/forum/topic/96567-installing-gt3582r-high-flow/#findComment-1710032 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,447 Member For: 17y 19d Gender: Male Location: Melbourne Posted 07/01/22 05:55 AM Share Posted 07/01/22 05:55 AM This post that I've quoted below has the details: On 07/11/2009 at 12:52 AM, Ricky N said: ... Specs for the original BA, BF & FPV turbo. (650hp turbo) Compressor cover: T04E .50 A/R. Compressor wheel: New GT. Inducer 61mm, Major 82mm. 6 bladed wheel. Turbine Wheel: New style GT35R. Major 68mm, Exducer 62mm. Turbine housing: GT35R. 1.06 A/R This is the compressor map but with a .70 A/R compressor cover not .50 A/R. ... Expand Link to comment https://www.fordxr6turbo.com/forum/topic/96567-installing-gt3582r-high-flow/#findComment-1710033 Share on other sites More sharing options...
dood1164 New Member 13 Member For: 3y 3m 22d Posted 07/01/22 06:12 AM Author Share Posted 07/01/22 06:12 AM Sweet as they're practically identical to those specs. A bit of a side note is there a rule of thumb of how much oil to prime the new turbo with. Cheers for all the help 🙂 Link to comment https://www.fordxr6turbo.com/forum/topic/96567-installing-gt3582r-high-flow/#findComment-1710034 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,447 Member For: 17y 19d Gender: Male Location: Melbourne Posted 07/01/22 06:19 AM Share Posted 07/01/22 06:19 AM you don't prime it at all; the falcon has a feature whereby you push the throttle to the floor and turn the ignition key and it runs the oil pump but not the ignition electricity... Do that for a few seconds and the oil goes all around the system (this is something you do after an oil change, too). 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96567-installing-gt3582r-high-flow/#findComment-1710036 Share on other sites More sharing options...
dood1164 New Member 13 Member For: 3y 3m 22d Posted 07/01/22 06:35 AM Author Share Posted 07/01/22 06:35 AM Wow awesome, that's super convenient cheers for all the help Link to comment https://www.fordxr6turbo.com/forum/topic/96567-installing-gt3582r-high-flow/#findComment-1710038 Share on other sites More sharing options...
Tom Tucker Donating Members 702 Member For: 5y 9m 30d Posted 07/01/22 07:47 AM Share Posted 07/01/22 07:47 AM Is the turbo you bought a copy, or genuine Garrett? Link to comment https://www.fordxr6turbo.com/forum/topic/96567-installing-gt3582r-high-flow/#findComment-1710039 Share on other sites More sharing options...
dood1164 New Member 13 Member For: 3y 3m 22d Posted 07/01/22 08:00 AM Author Share Posted 07/01/22 08:00 AM To be honest I have no idea. https://www.turbochargersplus.com/turbocharger-ford-falcon-xr6-g6e-f6e-gt3582-high-flow-billet-impeller-upgrade/#tab-description this is what and where I purchased it. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96567-installing-gt3582r-high-flow/#findComment-1710040 Share on other sites More sharing options...
Tom Tucker Donating Members 702 Member For: 5y 9m 30d Posted 07/01/22 08:31 AM Share Posted 07/01/22 08:31 AM that's not genuine. Hang onto that warranty! There seems to be some okay options around at the moment though, hopefully yours is one on them Link to comment https://www.fordxr6turbo.com/forum/topic/96567-installing-gt3582r-high-flow/#findComment-1710042 Share on other sites More sharing options...
