dutchy351 Member 41 Member For: 11y 5m 16d Posted 11/12/21 09:46 AM Share Posted 11/12/21 09:46 AM Hi guys I've recently finished building my engine and had it run up on a test cell. Everything has come up pretty solid but one thing I'm a little concerned about is the oil pressure. I'm running a ported horsepower junkie oil pump along with their high pressure relief spring Running 10w40 On cold start we are seeing 100psi @ 1000rpm At roughly 98-100 degrees we are seeing 32psi @ 1000rpm 52psi@ 2000rpm 80psi@ 4000rpm Does anyone think these pressures are to high or common for a Barra with these mods to the oil pump? Link to comment https://www.fordxr6turbo.com/forum/topic/96538-oil-pressure/ Share on other sites More sharing options...
adams355 Member 529 Member For: 8y 1m 19d Gender: Male Location: Brisbane Posted 11/12/21 10:15 AM Share Posted 11/12/21 10:15 AM What will be peak RPM? What oil filter is on it? How much power are you trying to make? Link to comment https://www.fordxr6turbo.com/forum/topic/96538-oil-pressure/#findComment-1709664 Share on other sites More sharing options...
dutchy351 Member 41 Member For: 11y 5m 16d Posted 11/12/21 10:47 AM Author Share Posted 11/12/21 10:47 AM Peak rpm is likely to be somewhere around 7k (cams suggest 6800rpm) Oil filter is a Ryco Looking to make around 1000 to the tyres Link to comment https://www.fordxr6turbo.com/forum/topic/96538-oil-pressure/#findComment-1709665 Share on other sites More sharing options...
adams355 Member 529 Member For: 8y 1m 19d Gender: Male Location: Brisbane Posted 11/12/21 11:07 AM Share Posted 11/12/21 11:07 AM You could wind it down a bit with their other option spring. 80psi @ 4000rpm is pretty high warm. You should be looking at 80psi around 7-8000 rpm. Those pumps are not going to fail but high oil pressure can cause other issues, its hard to know what's happening though. Give them a call see what they think. Link to comment https://www.fordxr6turbo.com/forum/topic/96538-oil-pressure/#findComment-1709666 Share on other sites More sharing options...
dutchy351 Member 41 Member For: 11y 5m 16d Posted 11/12/21 11:25 AM Author Share Posted 11/12/21 11:25 AM I dont actually think the have another option spring, this is one of their ported factory housings not one of their billet options. The only thing I could imagine could be the issue if it is one really is perhaps the pressure relief valve is stuck. Link to comment https://www.fordxr6turbo.com/forum/topic/96538-oil-pressure/#findComment-1709667 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 22d Gender: Not Telling Posted 12/12/21 12:07 AM Share Posted 12/12/21 12:07 AM For making over 35psi of boost you want the higher pressure relief spring. Obviously 1000rwhp will need about 35 to 40psi of boost, depending on the setup. I've ordered the inconel spring for my billet hp junkie oil pump, as most of the time I run about 35psi of boost. The spring is rated from 110psi to 160psi of oil pressure, depending where you set it. All of the above is information provided courtesy of hp junkie. I'm sure they'll be happy to field further enquires. I'm no expert but the old adage of running 20psi oil pressure at idle and 10psi per 1000rpm, isn't suited for every specific engine combo. Anywhoodle there's my 2c including gst. Link to comment https://www.fordxr6turbo.com/forum/topic/96538-oil-pressure/#findComment-1709668 Share on other sites More sharing options...
dutchy351 Member 41 Member For: 11y 5m 16d Posted 13/12/21 09:59 AM Author Share Posted 13/12/21 09:59 AM I suppose the one thing I'm trying to find is if it's safe or if I'm gonna have problems with this sort of oil pressure, if it's somewhat common to run this sort of pressure in higher power Barras without issues then I'm comfortable. Unfortunately this is not one of HP junkies full billet pumps just one of their ported stock pumps so as far as I'm aware no other options for springs. I've heard of factory pumps splitting however I'm certain this is due to a lack of porting on the housing and relief circuit. I'm also still running VCT and have heard there can be issues with it with high oil pressure also. Link to comment https://www.fordxr6turbo.com/forum/topic/96538-oil-pressure/#findComment-1709682 Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 22d Gender: Not Telling Posted 13/12/21 10:10 AM Share Posted 13/12/21 10:10 AM I ported and adjusted the relief on my stock body pump and it worked fine for ages. I also had billet gears, adjustable relief, billet back plate etc. Can't say with 100% certainty that the oil pump split and broke with my car but it seems like it. I had a stock spring with 5 or so turns into the relief. But yeah the pressure will be fine Link to comment https://www.fordxr6turbo.com/forum/topic/96538-oil-pressure/#findComment-1709684 Share on other sites More sharing options...
