Ford FGX XR6 N/A Ute axle removal (rear wheel bearings)
  • New Member
  • Member For: 3y 10m 9d
Hello,
I am at wits end trying to remove the live axle from my Ford FGX XR6 N/A Ute rear diff housing.
I am starting to think I have to remove clips from the diff centre.
I have used the disc method and also a sliding hammer to try and get the axle to shift - to no avail.
Any help would be hugely appreciated even just confirming I need to remove the clips behind the cover plate.
Thanks in Advance
John
  • Bronze Donating Members
  • Member For: 14y 5m 14d
I've had the the axles out in my FG M86 diff a couple of times. No clips in those. I just checked the factory manual for FG M80, no clips shown there either. Presume you have the retaining plate all undone and flopping around? It does usually take a good shock load to get them out if they've been in there a while.
  • 2 months later...
  • New Member
I thought I would post the outcome....
I got my local mobile mechanic to give it a go as I had no joy.
He had to apply tension using a portapower and then a slide hammer and it eventually it came out.
Here is a pic of the axle and bearing - It doesnt look like any bearing I have seen for the Ford FG Ute - Pretty heavy duty.
Could you pls tell me what diff it is?  3.45.
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 23d
good result :spoton:
yeah, it's likely a standard 3.45 diff. You can check the model# on the diff housing which will tell you the ratio (assuming it's still the same diff-center as when it left the factory).
  • Member For: 11y 3m 7d
late fg2's & fgx's came out with stronger wheel bearings, not the station wagon diffs of the earlier models. Some diff place's were offering this as a upgrade for people who used to carry weight in their ute's. I think ford copyed it as a running change (after they announced the end of falcon prodution)
  • 2 years later...
  • Member For: 9y 4m 13d
Expand
Now these bearings look pretty heavy duty have you ever changed one ?
I just bought fgx na ute which makes a God awful sound when taking off up to 10km
It's lsd I'm convinced it's either lsd clutches
Tailshaft is all org but just 1 or 2mm play on both cvs and centre bearing is orginal but no woobble etc
or the right rear bearing as it has done it once when taking of on a bumpy road turning left but I guess I'll have to wait for It to get worse to find it
