bodhi03 New Member 15 Member For: 3y 1m 28d Posted 02/12/21 05:55 PM Share Posted 02/12/21 05:55 PM hey guys, I own a 06 turbo bf mk1 sedan, and have recently noticed some strange noises. when the car is warming up, a rattling can be heard and its audible when sitting inside the car, however a tick happens in the engine bay and said noise pretty much disappears. I also discovered now a rattling noise when chucking my transmission into reverse. any suggestions what these could be? cheers Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,997 Member For: 16y 7m 18d Gender: Male Location: Melbourne Posted 02/12/21 09:44 PM Share Posted 02/12/21 09:44 PM We'd only be speculating as to the cause, realistically... try to use a long flathead screwdriver or pipe as a stethoscope to probe around to different parts of your engine bay to isolate the location it is occurring to begin with. Link to comment Share on other sites More sharing options...
hjtrbo Bronze Donating Members 320 Member For: 13y 10m 8d Posted 03/12/21 08:22 AM Share Posted 03/12/21 08:22 AM Welcome to Falcon life. My guess from recent experience. Your cold ticking noise -> Exhaust manifold bolts loose Your engine bay rattle -> Lower turbo heat shield will be split at the rear mounting bolt on the back of the dump pipe Also while you're there check the hot side flange bolts on the turbo. They'll probably be loose as well. Link to comment Share on other sites More sharing options...
