Leaking Radiator fluid
R ichard
  • Member For: 3y 11m 5d
 Hiya’ just Noticed a week or two ago that I’m leaking just below the thermostat,  can I drain the fluid and try undo the bolt and redo it up to see if it stops it leaking?
also thinking about replacing the thermostat, car has just done 180000km so was planning on cleaning out all the radiator fluid
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 9m 27d
You can do a flush and repair, but just re-doing it up is unlikely to fix your core problem. You probably need to clean up the connection points and perhaps replace the bit of flexible pipe.
  • Puff
  • Member For: 10y 8d
Change your coolant every 20,000km.
You gotta remove the pipe from the thermostat housing, clean the fark out of the pipe and the thermostat housing, replace the green o-ring that seals the pipe to the thermostat housing and reassemble it.
 Is that some what easy to do?
  • [IMPULSIV3]
  • Member For: 5y 10m 8d
@R ichard From the workshop manual, clearly shows where the O-ring is located :)
Pretty sure that step 2 is referring to item 3 in the table. If I'm not mistaken, the O-ring is part of the heater section of the cooling system.
though, doesn't really matter what its for, it just needs to be replaced periodically. Personally, I do when it starts leaking but preventative maintenance, like what puff recommended, is a better option.
  • Puff
The only reason I suggested to replace the o-ring is because it is leaking. I wouldn't call it a maintenance item and like you, I'd only fix it when it leaks. Even if it is apart for work, the old o-ring is going back in until it leaks.
