TheRanga New Member 11 Member For: 3y 7m 16d Posted 12/11/21 07:07 AM Share Posted 12/11/21 07:07 AM Im planning to put a walbro 525 into car, but it currently doesn’t have the turbo motor in and is na. If I change the stock one to this new one will I need a tune? Im not changing regulators. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/96495-safe-to-put-in-bigger-fuel-pump/ Share on other sites More sharing options...
Puffwagon Gold Donating Members 16,348 Member For: 10y 4m 27d Gender: Not Telling Posted 12/11/21 08:11 AM Share Posted 12/11/21 08:11 AM Yeah nah do some reading and you'll find out why you shouldn't do that. Failing that, as most do, I'll list a few reasons why you shouldn't; There is no need for a pump that big for an na car. A 525 needs an aftermarket reg to control the fuel pressure, no ifs or buts. A 525 will melt your wiring so you will have to install a relay and battery feed. It will add unnecessary heat to your fuel which makes for poor performance. It cost more than an appropriately sized pump. It doesn't fit the swirl pot without modifications. Even with an aftermarket reg you will probably run into return pressure issues, which means more modification to the swirl pot. So yeah moral of the story is you shouldn't install a 525, rather get another stock pump and you'll be apples. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/96495-safe-to-put-in-bigger-fuel-pump/#findComment-1709117 Share on other sites More sharing options...
