  • Member For: 10y 4m 24d
  • Gender: Not Telling
Up to you mate. You've already spent a bunch of money so a bit more won't hurt I guess.
It's a bit overkill for a BA motor but meh.
At least the oil pump gears won't sh*t the bed.
Nah the mods are overkill for the power and in that vein, overkill for a BA. That is a 1000hp turbo you're looking to fit although the stock internal gated turbo will make the power you're after. Same with the fuel pump, you only need a 255 on stock wiring with a stock reg.
Well you should be able to make some power once the motor is up to it.
Edited by Puffwagon
Got smacked with the tardle stick.
