Ammf6 New Member 22 Member For: 3y 8m 19d Posted 06/11/21 11:50 AM Share Posted 06/11/21 11:50 AM I’m in the process of finding a new cylinder head for my barra build. Ive got a turbo bf head which my builder said is to badly worn . my question is are all the cylinder heads from Na to turbo the same ?? I know the valves are different in the turbos . But are the castings the same ? My damaged turbo head casting numbers are - 3r23 - 6090- ac and I’ve just gotten a low k bf gas cylinder head with the same casting numbers - 3r23 - 6090- ac , the only thing that looks different with the two side by side is the turbo one has a cross / X pattern shape on the front of the alloy casting where the Na one is just smooth . Are the Na heads fine to use on a turbo application with upgrading the valves and valve springs of course . Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,948 Member For: 16y 7m 6d Gender: Male Location: Melbourne Posted 06/11/21 12:37 PM Share Posted 06/11/21 12:37 PM yeah, cylinder head is the same, just the valves and valve springs upgraded is fine... and studs while you're at it. Link to comment Share on other sites More sharing options...
