bodhi03 New Member 15 Member For: 3y 7m 9d Posted 30/09/21 08:18 PM Share Posted 30/09/21 08:18 PM hey guys, was just wanting to ask if its risky to push more power out of my 06 bf mk1? im running 16psi on stock turbo w a flapper mod pushing 460 hp, around 217k kms on engine, but have wanting to upgrade the turbo to potentially a pulsar gtx and get an external waste gate. with the upgrades I was aiming for at least the 500 hp mark and maybe 17 or 18 psi to achieve that. is there a risk to any of this as I know mk1 have weaker internals e.g rods. if anyone can give some insight I would appreciate it. cheers :) Link to comment https://www.fordxr6turbo.com/forum/topic/96438-risky-to-push-more-power-out-of-my-turbo-bfmk1/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,490 Member For: 17y 29d Gender: Male Location: Melbourne Posted 30/09/21 10:43 PM Share Posted 30/09/21 10:43 PM Your stock turbo can easily make 500hp (or ~373kW in the measurement we actually use all over this site) at the wheels... you're already well above the safety area of the stock internals weak-rods engine, though with 460hp (~343kW) if you're making that at the wheels, so bottom line is, if you've got the budget for an engine rebuild, send it Link to comment https://www.fordxr6turbo.com/forum/topic/96438-risky-to-push-more-power-out-of-my-turbo-bfmk1/#findComment-1707933 Share on other sites More sharing options...
Tom Tucker Donating Members 703 Member For: 5y 10m 9d Posted 01/10/21 02:05 AM Share Posted 01/10/21 02:05 AM Welcome mate. I suspect if you run e85 and ramp the boost and power on progressively it might be ok. The stock turbo is superior to a pulsar or anything else for that matter, up to around 440rwkw. Don't touch it unless it is damaged. Link to comment https://www.fordxr6turbo.com/forum/topic/96438-risky-to-push-more-power-out-of-my-turbo-bfmk1/#findComment-1707935 Share on other sites More sharing options...
bodhi03 New Member 15 Member For: 3y 7m 9d Posted 01/10/21 05:41 AM Author Share Posted 01/10/21 05:41 AM 7 hours ago, k31th said: you're already well above the safety area of the stock internals weak-rods engine when u mean well above the safety area, do you mean pushing 343kw is already a risk with a mk1 engine? Link to comment https://www.fordxr6turbo.com/forum/topic/96438-risky-to-push-more-power-out-of-my-turbo-bfmk1/#findComment-1707937 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,490 Member For: 17y 29d Gender: Male Location: Melbourne Posted 01/10/21 06:01 AM Share Posted 01/10/21 06:01 AM yep, anything above 300rwkw is pushing the stock skinny-rod motor. Link to comment https://www.fordxr6turbo.com/forum/topic/96438-risky-to-push-more-power-out-of-my-turbo-bfmk1/#findComment-1707939 Share on other sites More sharing options...
bodhi03 New Member 15 Member For: 3y 7m 9d Posted 01/10/21 07:38 AM Author Share Posted 01/10/21 07:38 AM is there any way to minimise the motor from sh*tting itself? like for example more cooling or whatever. Link to comment https://www.fordxr6turbo.com/forum/topic/96438-risky-to-push-more-power-out-of-my-turbo-bfmk1/#findComment-1707941 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,490 Member For: 17y 29d Gender: Male Location: Melbourne Posted 01/10/21 07:44 AM Share Posted 01/10/21 07:44 AM nah, it's cylinder pressure that bends conrods... that pressure barely changes with any sort of cooling protocol unless you use a completely alternate fuel, as the higher the boost you run with the same size turbo, the more pressure/heat is generated in the intake charge. Link to comment https://www.fordxr6turbo.com/forum/topic/96438-risky-to-push-more-power-out-of-my-turbo-bfmk1/#findComment-1707942 Share on other sites More sharing options...
bodhi03 New Member 15 Member For: 3y 7m 9d Posted 01/10/21 10:44 PM Author Share Posted 01/10/21 10:44 PM I have a e85 tune but run 98 pre much daily, would that make any difference? Link to comment https://www.fordxr6turbo.com/forum/topic/96438-risky-to-push-more-power-out-of-my-turbo-bfmk1/#findComment-1707946 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,490 Member For: 17y 29d Gender: Male Location: Melbourne Posted 02/10/21 12:39 AM Share Posted 02/10/21 12:39 AM E85 does reduce cylinder pressures, but then you compensate by adding extra timing which increases it again, but E85 does run cooler than 98 so it is better (for a bunch of other reasons, too haha). Link to comment https://www.fordxr6turbo.com/forum/topic/96438-risky-to-push-more-power-out-of-my-turbo-bfmk1/#findComment-1707949 Share on other sites More sharing options...
