norrs Donating Members 448 Member For: 17y 9m 8d Gender: Male Location: Darwin Posted 20/09/21 01:43 PM Share Posted 20/09/21 01:43 PM Ok so the car started running rough and I got these codes, p1381 and P1386. I've also had p1388 once. so after much research on here I pulled the rocker cover. The timing chain lines up fine on the cams so it hasn't jumped a tooth. The guides all seem ok, there is a minor chip at the top end of the drivers side one but from what I understand that's normal. However, when the top indicator chain links are all at 12pm on the cams the mark on the crank pulley is a bit out to the left. I'm not sure if this is normal. I'll put a pic below. If I line the crack pulley marker up, the chain marker are still rather close to the centre but they are certainly lined up on the marker on the cam sprocket. Anyway, I have new coils, I checked the spark plugs and plug gaps. I cleaned the cam solenoids. I checked their Ohms and they seems ok. I checked the power to them and that seemed ok. I've also replaced the sh*ty connector plugs to them as they fell to bits. Anyway I put it all back together and I still have the same issue p1381 and p1386 and it's running rough as hell like it's misfiring. So my questions:1. Should the crank pulley mark line up perfectly when the timing chain markers are all at 12 o'clock. 2. How can I check the solenoids further?3. Any other ideas? Link to comment https://www.fordxr6turbo.com/forum/topic/96428-another-cam-timing-issue/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,451 Member For: 17y 20d Gender: Male Location: Melbourne Posted 20/09/21 11:09 PM Share Posted 20/09/21 11:09 PM are they orange or yellow chain markers? it should look like this at the top with both being yellow. here's how it should look at the bottom, which is difficult at best to check with the balancer in the way. I'm pretty sure the resistance is the only qualitative way of checking the phasers other than logs on a dyno. Link to comment https://www.fordxr6turbo.com/forum/topic/96428-another-cam-timing-issue/#findComment-1707707 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 9m 8d Gender: Male Location: Darwin Posted 20/09/21 11:54 PM Author Share Posted 20/09/21 11:54 PM Yeah they look orange but they are the yellow ones. I've seen the orange one because I turned it over like 60 times to double check. What do you reckon about the crank pulley mark? Is that within range? Link to comment https://www.fordxr6turbo.com/forum/topic/96428-another-cam-timing-issue/#findComment-1707709 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,451 Member For: 17y 20d Gender: Male Location: Melbourne Posted 21/09/21 12:21 AM Share Posted 21/09/21 12:21 AM I don't think the crank-pulley even has a mark that's relevant to timing... I could be wrong, though. Link to comment https://www.fordxr6turbo.com/forum/topic/96428-another-cam-timing-issue/#findComment-1707711 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 30d Gender: Male Location: Adelaide Posted 21/09/21 12:40 AM Share Posted 21/09/21 12:40 AM (edited) Mate you’re 100% out a tooth on the bottom sprocket timing cover off and go for it ! Keif … you’re wrong as it has a Keyway which I’ve seen the dowel pin missing or slipping/bent before Everything has a “Home” and a mark or pin locator, you can’t actually stuff it up so when it doesn’t line up it’s guaranteed too be out Edited 21/09/21 12:42 AM by JETURBO Link to comment https://www.fordxr6turbo.com/forum/topic/96428-another-cam-timing-issue/#findComment-1707712 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,451 Member For: 17y 20d Gender: Male Location: Melbourne Posted 21/09/21 02:03 AM Share Posted 21/09/21 02:03 AM of course it has a keyway, if it didn't have a keyway it'd literally slip off the shaft... anyway, I'm happy to be wrong if it has a mark that's relevant. Link to comment https://www.fordxr6turbo.com/forum/topic/96428-another-cam-timing-issue/#findComment-1707714 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,314 Member For: 10y 3m 1d Gender: Male Location: South Australia Posted 21/09/21 02:12 AM Share Posted 21/09/21 02:12 AM The mark on the harmonic balancer lines up with the mark on the timing cover when cyl 1 is at tdc. Also the phaser dots should be at 12 o clock. The mark has to be exactly spot on and the engine has to be wound over clockwise to get the cams lined up accurately. The only way that mark wont line up is if the chain has jumped on the crank sprocket or the balancer has slipped on the rubber dampener. Link to comment https://www.fordxr6turbo.com/forum/topic/96428-another-cam-timing-issue/#findComment-1707715 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 30d Gender: Male Location: Adelaide Posted 21/09/21 02:12 AM Share Posted 21/09/21 02:12 AM No the bolt holds it on the keyway holds it in correct position and locks in in place in the correct 360* otherwise the valley mark on the outside that you can see in OP’s picture wouldn’t have relevance to anything hence his being at the 10 o’clock mark which needs to be 12 o’clock with everything else lined up Link to comment https://www.fordxr6turbo.com/forum/topic/96428-another-cam-timing-issue/#findComment-1707716 Share on other sites More sharing options...
norrs Donating Members 448 Member For: 17y 9m 8d Gender: Male Location: Darwin Posted 21/09/21 03:20 AM Author Share Posted 21/09/21 03:20 AM I've seen some people pull the timing cover off and fix this issue with the engine in car but realistically is this an engine out job? Link to comment https://www.fordxr6turbo.com/forum/topic/96428-another-cam-timing-issue/#findComment-1707719 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,314 Member For: 10y 3m 1d Gender: Male Location: South Australia Posted 21/09/21 03:32 AM Share Posted 21/09/21 03:32 AM On 21/09/2021 at 3:20 AM, norrs said: is this an engine out job? Expand No farken way mate in any way shape or form do you pull the engine out to remove the timing cover. Link to comment https://www.fordxr6turbo.com/forum/topic/96428-another-cam-timing-issue/#findComment-1707720 Share on other sites More sharing options...
