TomTerritory Member 40 Member For: 3y 8m 2d Posted 10/09/21 03:31 AM Share Posted 10/09/21 03:31 AM If I install an aftermarket head unit (single din in the tissue box) will I lose the reverse sensor beeps? I do love those beeps.. 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,242 Member For: 16y 10m 10d Gender: Male Location: Melbourne Posted 10/09/21 04:25 AM Share Posted 10/09/21 04:25 AM if you get the signal from the stock speakers as "input" into your headunit then output from the headunit to "whatever" audio, then yeah, you can keep all audio output... to get this sort of thing to work isn't great at high volume, though. Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 3y 8m 2d Posted 10/09/21 06:17 AM Author Share Posted 10/09/21 06:17 AM Sounds like a good work around! So if I use a line converter I can then have an rca to 3.5mm audio jack cable into the front of the new head unit. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,242 Member For: 16y 10m 10d Gender: Male Location: Melbourne Posted 10/09/21 09:03 AM Share Posted 10/09/21 09:03 AM you could, but like I said, that sucks for audio quality especially at high volume if you're going to amplifying it etc Link to comment Share on other sites More sharing options...
El Andrew Gold Donating Members 2,036 Member For: 9y 9m 28d Gender: Male Location: Canberra ACT Posted 10/09/21 11:04 AM Share Posted 10/09/21 11:04 AM Could you wire the signal from factory unit to a small extra speaker you mount somewhere just for the beeps and then run the existing speakers off the new head unit? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,242 Member For: 16y 10m 10d Gender: Male Location: Melbourne Posted 10/09/21 11:07 AM Share Posted 10/09/21 11:07 AM that's definitely a better option... Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,134 Member For: 10y 21d Gender: Male Location: South Australia Posted 10/09/21 11:10 AM Share Posted 10/09/21 11:10 AM Beep beep I'm a sheep 1 Link to comment Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 1m 11d Gender: Male Posted 10/09/21 12:10 PM Share Posted 10/09/21 12:10 PM Or pick up off the canbus the signal for distance and replicate the sound yourself. I thought about it but cbf, I custom wired the reversing camera and have eyeballs so figured that was good enough Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 3y 8m 2d Posted 11/09/21 02:02 AM Author Share Posted 11/09/21 02:02 AM Thinking about wiring both outputs (standard unit and new unit) to the front speakers using this method https://www.epanorama.net/circuits/linesum.html Link to comment Share on other sites More sharing options...
