Rocker cover rear seal bolt snapped HELP Please
Mrp40l
  • Member For: 3y 6m 5d
Hi guys I am in a bit of worry with my 03 Ba xr6. On inspection of an oil leak I came across bent rear rocker gasket causing bad leak and on removal of rocker cover I noticed a bolt missing on the rear driver's side, so I removed the cover and a closer look I seen thr bolt must of snapped off and is now stuck in the thread. So question is can I remove the girdle thingy above camshaft to then take to bench and try to easy out the stuck bolt half way into the thread??
  • less WHY; more WOT
  • Site Developer
  • Member For: 16y 9m 8d
they're called "cam caps" and yeah, you should be able to take them out (make sure they go back where they came from) and go an easy-out or whatever is necessary to get the snapped thread out.
Thanks heaps k31th. I will post again after I take it out and attempt to easy-out the thread , if all fails then I will have to try and source the cam cap(s) from an either broken barra or purchase a doner engine per say. If the easy-out way doesn't go to plan, do you think a tap and die could work, or will it ruin the seal on the cover with an aftermarket bolt/seal?
  • Trust me bro...
  • Member For: 9y 11m 19d
You can't just use another cam girdle as they are matched to the head.
If you can't confidently remove the broken bolt without farking it up, pay someone to do it. A bolt doctor or the like will come to you and have it out in no time.
Update,  I removed the rear cam girdle, took it to bench and after a good hour of careful drilling and trying the easy-outs with not much luck I was about to give u and take it to the "doctor of the bolt" when I just said stuff it and I gave it another go this time drilling all the way through the old left over bit of bolt, I then got a larger easy-out to finally get grip and got it out & was very happy to say the least! Thanks guys for the assistance
