Retarded timing
Frank Castle 85
  • Puff
  • Member For: 9y 10m 12d
There is a very high chance your bits were put in if the place is reputable. Letting small sh*t go like lifters or various other things that "should be right" is common place. Would you even be doing anything about it if there wasn't a noise? The old case of yeah nah she'll be right...until it isn't.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 6m 10d
Yeh look 9/10 engines I would build typically would run donor engines lifters as there’s very low chance they’re ever an issue …. That said the new big banger engine going in the ute has a full set of Atomic lifters at the horrendous price of nearly a kidney !
  • 2 weeks later...
  • Member For: 20y 2m 18d
Is it like an almost buzzing sound but definitely metallic?
Also what do you mean the noise can be lifted with the Haltech?
I am fairly sure I run the same cams.
Are you guys absolutely certain its not timing chain related?
  • Member For: 5y 5m 11d
Apparently mucking around with cam timing settings is able to move the rpm of the sound.
The brand new hd chain guide was changed out again as well because apparently it had a mark on it. And it has a new hd sprocket. Pretty much everything is brand new.
I haven't actually heard it, I'm just letting the tuner work through it
Interesting;
Im trying to understand how the cams them selves could contribute to noise within the valve train, but can’t get my head around it.
I wonder if it’s registering any false nock because of it.
Good luck with it bud!
