Reputable tuner singing a different tune to the forum...
FGeorge
  • Member For: 5y 7m 6d
"I'm told that the only option is to get a waste gate and turbo actuator to stop a mechanical problem from eventuating."
Does the reputable tuner mean an external wastegate to consistently achieve the target boost level?
Cause My T has the flapper mod and TS actuator on a high flow billet wheeled 3582 with a 4" dump, cat and 3.5" catback and it boost spikes to 20psi on occasion (16psi target on 98) according to the torque pro app. I believe I hear the actuator belching excess boost into zorst at times.
Previous tune was 20.5 psi and never heard that particular noise, only the blow off which was quite loud when u got of it. Who knows what it was boost spiking to then or maybe it was tuned better then?
Having said that it uses no oil and has good oil pressure, but is not nearly as much fun.
  • [IMPULSIV3]
  • Member For: 5y 11m
Same boost spikes as me and you had the flapper mod??
Now that's interesting!
Maybe its a tune thing? 🤔
Yep flapper mod included.
The turbine wheel is a 9 blade instead of the factory 11 blade.
Target afr on dyno charts not smooth like we often see here, so fuel trim must be a bit loose, may have something to do with it?
