gaz097 Bronze Donating Members 1,752 Member For: 13y 4m 27d Posted 13/08/21 07:54 AM Share Posted 13/08/21 07:54 AM Did you research this at all before starting?You have to grind the housing too. Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 3y 6m Posted 13/08/21 10:15 AM Author Share Posted 13/08/21 10:15 AM yeah realise this now. Did not think I had to with the 37mm flapper. I’ve ground it out now and it seems to seal ok. Albeit not perfect. Slight bit of light coming out but better than before. 1 Link to comment Share on other sites More sharing options...
finnas Gold Donating Members 105 Member For: 14y 11m 6d Posted 15/08/21 11:50 AM Share Posted 15/08/21 11:50 AM Any pics? Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 3y 6m Posted 16/08/21 01:33 AM Author Share Posted 16/08/21 01:33 AM Its a bit of a botched job really, not too keen on posting pics and getting flamed for it! Anyway see image, please be kind... While grinding the housing I marked up the sealing surface. Got me a bit annoyed, I was rushing a bit as I had a good welder lined up to do the weld for me that night. Thinking about pulling the actuator arm out and taking it into work and getting the face milled to clean up the surface. Testing with light it doesnt look too bad though, but obviously not perfect. See short vid of me testing it with light. https://youtube.com/shorts/P1_fapaKPCI?feature=share Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,040 Member For: 16y 8m 8d Gender: Male Location: Melbourne Posted 16/08/21 01:38 AM Share Posted 16/08/21 01:38 AM your video is marked as "private"... change it to "unlisted" so we can see it. Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 3y 6m Posted 16/08/21 01:43 AM Author Share Posted 16/08/21 01:43 AM Whoops, had it scheduled. Fixed it Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 3y 6m Posted 16/08/21 03:14 AM Author Share Posted 16/08/21 03:14 AM Easier in the drill press with 40mm grinder bit Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 3y 6m Posted 16/08/21 11:07 PM Author Share Posted 16/08/21 11:07 PM Next question, how much pre-load should I set the actuator up with? I dummy set the arm up with a bit over 1/2 a hole and put pressure on the actuator (co2..) and the hole lines up at ~4psi, so the actuator begins to open around 4psi. Shall I pre-load it a bit higher ~ 6-8psi. Will that make it easier to control boost a bit higher? Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 3y 6m Posted 17/08/21 12:50 AM Author Share Posted 17/08/21 12:50 AM Nevermind… dumb idea it runs out of stroke at 10psi so I would just be limiting how much it opens! Actually surprised at how little it opens. this is what I measured for pressure Vs travel for reference. 0psi = 0mm 4psi = 4mm 6psi = 10-11mm 8psi = 17-18mm Link to comment Share on other sites More sharing options...
TomTerritory Member 40 Member For: 3y 6m Posted 23/08/21 05:56 AM Author Share Posted 23/08/21 05:56 AM Update, got it tuned. They couldnt control the boost below 16psi 😭 So they set the rev limter to 5,200rpm as they were running out of fuel to tune it at that psi. Still it made 248kW @ 5,200rpm. The tuner was a local tuner who has pcmtec and an awd dyno. Not sure why they didnt try this but I am going to try and bypass the boost control solenoid and see if that's causing overboost. Otherwise my porting job was no good... Link to comment Share on other sites More sharing options...
