Puffwagon Puff Gold Donating Members 16,134 Member For: 10y 21d Gender: Male Location: South Australia Posted 24/06/21 12:07 AM Share Posted 24/06/21 12:07 AM I've made 427awkw on e85 with a stock territory exhaust, except it had a slightly better cat, but not a decent 100 cell one or anything, so basically stock. A stock or near stock exhaust will make a bunch of power and a free flowing one will make more power. Link to comment Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 5m 15d Posted 24/06/21 12:16 AM Share Posted 24/06/21 12:16 AM Ah ok - thanks. I'm currently ~300rwkw on 98 and ~350rwkw on E85 but with E85 not available here in NZ for less than $4/L (and it's not a pump, you have to buy a 200L barrel....) I'm wanting to bring my 98 game up via a turbo upgrade but wasn't sure if stock exhaust (with dump and venom cat) would be ok with ~400rwkw.... Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,134 Member For: 10y 21d Gender: Male Location: South Australia Posted 24/06/21 12:24 AM Share Posted 24/06/21 12:24 AM It's fine to use a stock exhaust with a turbo upgrade but you should be planning to upgrade the exhaust eventually. You have to push the turbo a lot harder to make power with a restrictive exhaust which isn't optimal. One or the other might gain 20kw each, but done together will net more than the sum of the parts. Link to comment Share on other sites More sharing options...
VDSY Member 37 Member For: 4y 3m 1d Posted 24/06/21 01:36 AM Author Share Posted 24/06/21 01:36 AM is there really any way to get 450kw on 98 without a built engine? ive seen up to 430kw on 98 unsure of happy dyno but no tuners really push on 98 for obvious reasons Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,134 Member For: 10y 21d Gender: Male Location: South Australia Posted 24/06/21 01:58 AM Share Posted 24/06/21 01:58 AM Having a built motor doesn't really make a difference. You don't see much more than 400 on 98 with stock size turbos, because it reaches the knock limit of the fuel. You can make plenty more if you have the right bolt ons, but you will sacrifice the street manners that a small turbo provides. Link to comment Share on other sites More sharing options...
VDSY Member 37 Member For: 4y 3m 1d Posted 24/06/21 02:02 AM Author Share Posted 24/06/21 02:02 AM What are the bolt ons? bigger turbo which results in more lag? Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 4m 11d Gender: Male Location: Mildura Posted 24/06/21 02:02 AM Share Posted 24/06/21 02:02 AM I'm hoping to push 450-480rwkw with the aeroflow 6762 with 1.15ar rear housing haha Link to comment Share on other sites More sharing options...
VDSY Member 37 Member For: 4y 3m 1d Posted 24/06/21 02:03 AM Author Share Posted 24/06/21 02:03 AM On 98? when would full boost be with that setup? Link to comment Share on other sites More sharing options...
NA_TURBO Member 532 Member For: 9y 4m 11d Gender: Male Location: Mildura Posted 24/06/21 02:05 AM Share Posted 24/06/21 02:05 AM Yeah on 98, no E85 up here. Not sure when boost will be on but I have a 4000rpm stall so it won't make a great deal of difference for me. Link to comment Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 5m 15d Posted 24/06/21 02:05 AM Share Posted 24/06/21 02:05 AM 1 minute ago, VDSY said: On 98? when would full boost be with that setup? YES! 🤣 1 Link to comment Share on other sites More sharing options...
