Highest HP numbers on 98? (HP,NM,Psi)
VDSY
  • Member For: 4y 3m 1d
Interested to see what the people have made on 98! (For the people that live too far away from e85) 🤣
Standard engine or built, 😃
Hp and nm, Psi and full boost by rpm? (if you know)
Heck why not say the turbo too
Thanks!
  • Member For: 6y 5m 15d
Auto. ZF. 2015 FGX
Nah not yet. No need. I don't limiter bash it.
Makes 345rwkw on E85 but unfortunately after shipping it home to NZ, Gull pulled E85 from the pump so running it only on 98 now. Although we have 100+ octane petrol at pump here but it's a good 45min drive for me so 98 it is.
  • [IMPULSIV3]
  • Member For: 5y 10m 22d
316KW at the hubs
675nm derived torque
~18psi
Stock FG turbo, 2010 fg on BP98 :)
Stock motor (with billet pump gears), 255 in-tank pump, 1000cc injectors, 4" dump & hi flow cat (stock cat back w/ mid muffler delete).
All other typical bolt-on's and a 1000hp plazzy ic.
Created a thread for the journey of the rig with goals to get 310kw if you wanna see more specifics :)
Edited by biddie_fiddler
added boost
  • [IMPULSIV3]
She's a boost creeper for sure, sometimes get 20psi which probably isn't ideal...
From memory it was tuned to 16-18psi, and it doesn't often creep over 18psi. Rob (Monsta Torque) did say this would happen with the stock turbo, heard its a common issue.
Just needs to last till I can afford a new turbo xD
