  • Member For: 4y 19d
Na I am pretty sure its built ive got 3 cars at my place with the btr but this one does seems really tight, 2nd gear actually wheel spins aswell, so I am pretty sure its built.
SILLY QUESTION: As for the green top, would a N/A green top do?
If yes then isnt that basically throwing all the turbo components into a N/A engine?
Or am I just changing the bottom end into  green top?
Sorry guys but I am  gonna be asking them silly question as I am very new to the scene so just excuse me for the silly questions
  • Member For: 4y 3m 10d
I would swap the entire engine out rather then taking two engines apart as a 248k engines valve springs are Probably tired and depending on maintenance could have shagged cams and timing gear as well
there's no such thing as a factory turbo green top all green tops were NA gas motors but that's a good engine for boost
no such thing as a silly question ask away,, there is heaps of info already on the forum 99% of the questions you will want to ask have answers already on the forum so search away :)
Edited by TRYME
Skip the ZF if the BTR is built just drop that into your turbo, ZFs are very expensive to play with when there's issues and then theres the whole
mating it to the car debarcle don't really see it being worth your cash for what im
assuming you want to do......
Yea you got the right idea but the green top
Will Still need The supporting stuff like fuel system and intercooler to make good power
  • Member For: 10y 1m 13d
Is it just me, or if you are buying a motor so you don't break your current motor, you might as well go full send on your current motor?
If it breaks, then buy a motor like you were already planning...
If it doesn't break, then happy days...
'Weak' is relative to the later Barras - you can still have a turbo Barra motor at 280-300 and if it is well tuned and maintenance kept up there's no reason why it won't be a fun, reliable street car.
El Andrew you have a fair point, not saying your wrong or anything but I was just looking at it in a different way ..... I was looking at it in the way of saving the guy money in paying for tuning twice as well as the fact the motors got an unknown history and 250clicks is a lot of kays.... I know it's a Barra but still
back when I had a BA everyone said oh 300 is cool for a BA no worries... I was running a 290rwkw tune from autotech and at around 130 clicks motor was rooted.. and I took good care of that car Maintenance wise.... my Good friend also lunched his BA engine running similar  power tuned by C&V..... tbh I personally don't think a BA engine with that many Kays with an unknown maintenance history has any business seeing more boost but then again your right he mite want to just send it and see how it goes.......  but I still reckon he's better off with the gas motor from
The beginning only pay for a tune once and he can lean on it more give it a proper hiding and not have the worry in his mind that Rodney mite appear...
Hey guys (its me again lol)
I was going to attempt to block the bov, does anyone have a diagram of where the bov is and which two holes I should be blocking, I dont wanna be taking out and blocking random pipes,
Any help appreciated!
Edited by 05xrt6
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 25d
there's 3 pipes going to the BOV: two bigger ones including one from the throttle body side of the cross-over (underneath) and it goes to the "inlet" for the BOV and the other one goes from the "outlet" which is a pipe that goes to the "fresh air" side of the crossover. The third one is a smaller vacuum hose that goes from the "top" of the BOV to a t-piece connected to the inlet manifold.
With the option of "disabling" the BOV, you take the "top" one off and plug the vacuum hose with a screw that digs into the hose to seal it from being able to vent to atmosphere.
With the option of "removing" the BOV, you do the same blocking for the "top" as well as removing to the two bigger pipes and then plugging the parts left empty with chair stoppers (for the least sophisticated option).
