Transmission fault code
josh883
  • Member For: 7y 8m 23d
The point is it needs to be full, you can guarantee that doing it when cold. I have heard of a lot of transmissions failing because the fluid was dirty or it didn't have enough fluid in it. I have never heard of a transmission being over filled, well at least not a ZF because you can only get a certain amount in before it will drain out. I'm not here for forum kudos, I worked as a mechanic years ago and still do all my own work at a friends shop. We went through this all 3-4 times last year filling and refilling the ZF.
We followed the ZF procedure on 2 different occasions and when I drove the car hard it went into limp mode. A transmission shop recommended filling when cold so I tried that and got a litre in or so. Had no dramas since x 2. You cant guarantee the conditions to be perfect on every transmission with the 'warm' theory. We live in Australia it is basically warm all the time. I have a trans fluid temp gauge on mine and it is usually at 25 degrees every morning when I start the car and only takes a few minutes to be over 30C.
  • Trust me bro...tbh ;) 8===}
  • Member For: 9y 11m 26d
Yeah nah I know what the official recommendation is and it is wrong. Do it from cold or you will underfill it. :secret:
I mean cold as in the first start for the day, not after running for a minute. Literally have someone in the car, raise the hoist, get them to start the car and put it into drive and start filling until it comes out. I spose if you live in nth qld then 30c might be your starting point.
  • [IMPULSIV3]
  • Member For: 5y 9m 26d
What @NA_TURBOis trying to attached is a ZF oil service manual. Click this link to get it, it'll download straight away.
The full link is below:
https://www.audiworld.com/forums/attachments/q5-sq5-mki-8r-discussion-129/94518d1521842717-q5-transmission-service-fluid-change-zf_si_oelwechselkit_50145_en.pdf
