biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 5y 10m 23d Gender: Male Location: Perth, WA Posted 02/03/23 01:14 PM Author Share Posted 02/03/23 01:14 PM There are two mixers shafts, one for passenger side and one for drivers side. Passenger side can be replaced without dash removal (with some hassle as you can see), driver's side is a dash out job. Your issue could be because of shaft, it could also be the HIM itself, like a stripped gear inside it. Could be the flaps too. In any case, most of these issues are a dash out job. You'll need to download the workshop manual and go through the troubleshooting tables to narrow down the issue you're having. Link to comment Share on other sites More sharing options...
QIKAZZ New Member 2 Member For: 1y 11m 19d Posted 02/03/23 08:35 PM Share Posted 02/03/23 08:35 PM Thanks mate, I'm new here and don't have the workshop manual. Any ideas where I can find it? Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 5y 10m 23d Gender: Male Location: Perth, WA Posted 02/03/23 11:29 PM Author Share Posted 02/03/23 11:29 PM (edited) There is a "workshop manual" thread on the forum but it's a little tedious to find replies with up to date links. In any case, here is Mk1 FG workshop manuals. Mk2 should be similar enough, if not identical Edited 02/03/23 11:30 PM by biddie_fiddler Link to comment Share on other sites More sharing options...
Kris limmer New Member 9 Member For: 4y 11m 12d Posted 11/03/23 09:16 PM Share Posted 11/03/23 09:16 PM (edited) Ford can do a touch point recalibration after you have found the problem, alot of cars have ongoing problems because their local Ford dealer and the owner dont know this, they replace the parts and expect it to be good for 20 years, the flaps/blend doors that the mixer shafts go through break also, it's a seats, hand brake leaver, center console, icc, drop steering column then dash out job I posted up photos when I did mine, you'll need to join this group, Friend me on FB, PM me ill help you out if you get stuck, https://m.facebook.com/groups/clubfgaus/permalink/2815036938792346/?mibextid=Nif5oz Edited 11/03/23 09:19 PM by Kris limmer Link to comment Share on other sites More sharing options...
