  • Member For: 18y 11m 15d
Before I could start assembling the car, I had to finish the body. I spent a lot of time on the body, making sure that everything was as good as it could be. The results speaks for itself...
After the white was applied, the firewall blackout was finalised..
  • Like 2
Somewhere around this time, I started purchasing parts for the driveline. Now, remember when I said that this was going to be a restoration... This is where things started to change from the intended path.
Originally, I had intended on just installing a stroker kit. My engine told me that I would waste my money going down that path, as the standard manifold wouldn't support it to its full potential.  I'm not one to waste money. So the original engine and gearbox were put on a pallet and stored.  The search for an alternative heart commenced.
While searching the net I can across this. I contacted the seller and soon enough, the engine was on its way from W.A. It's a SS Group A, 4 bolt mains block. It had Yella Terra forged rods and Ross forged pistons. The block has fire rings and was set up for boost.
The engine was originally built by Mark's Workshop in W.A and stored as the previous owner had changed direction. The engine is still awaiting a full strip down, clean and reassembly. I have everything for the engine except a camshaft (Hydraulic roller). Sourcing a billet for the engine has proved difficult and we have aske Ivan Tighe to make us a unit to our specifications.
img%5D
Oops. Forgot to show the inside of the doors...
Edited by HI PSI
  • Like 3
Thanks Puff. I can understand why so many divorces result from car builds. The time involved is immense. Let alone the financial commitment.
Once I got the engine, I wanted to keep the Grp A theme running... I sourced a set of bare Grp a heads. Unbeknown to me, the heads had a LOT of material removed form the sealing surface. So much so that we had to get a 0.120" head gasket. The heads had received some major porting work and flowed around 640 hp.
I had the heads fully reconditioned, with new Manley valves, Isky and Lunati springs along with genuine Grp A roller rockers.
Edited by HI PSI
  • Like 2
