  • New Member
  • Member For: 4y 1m 19d
Hey everyone im after some advice about an issue that has raised it's ugly head in the last couple of weeks with my 08 XR6T.
I took it in for a service with Ford (130,000km's) in Feb and was advised that the car has a timing cover leak, which from my research sounds like a common problem that can develop with these cars. The bloke at Ford quoted me $1600 to fix (that's for labour). However, fast forward to last week and I noticed a vibration in the steering and a noise coming from the engine bay. I checked the power steering reservoir and saw that it was almost empty so I replaced the fluid and the vibration and noise went away. I havnt noticed any engine oil leaks or the engine oil level dropping, but there is an obvious (and bad) leak in the power steering system somewhere.
My question is: Could the two issue be related, in that a leak in the timing cover could cause the power steering fluid to leak like it is but not the engine oil, or is the Ford bloke trying one on me to the tune of $1600?
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 20d
it's a time consuming job to remove the timing cover, so $1600 is a reasonable quote, but not a good one... another mechanic might be able to do it cheaper
No, the power steering system is completely separate to a leak in the timing cover.
  • Member For: 10y 7d
Not related as they are completely separate unless Ford mistook oil mess to be from the timing cover when it was actually PS fluid. Unlikely though. You wouldn't notice a drop in oil level with the timing seal unless is was a huge leak but would probably see some oil hanging around on your sump as it runs down the engine.
Ford did my FG XR6T timing cover seal (along with sump, rocker cover, spark plug and crank pulley seals that you do at the same time) for $980. I'd ring a few Ford dealers and get some quotes that are hopefully closer to that - even if you go back to your dealer and get them to match it.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 30d
It’s a highly possible situation that yes he’s buggered the quick diagnosis as when it’s all coated in dirt and dust and all covered your sump in mess that yeh you might have the other “Typical” FG power steering leak going on
Nip up the 16mm fitting on the bottom inlet hose attached to the power steering assembly and I bet it’s loose enough to justify the leak
degrease and away you go ;)
