Aeroflow 7075 on Barra, interested in peoples experience with this turbo or equivalent, power, rpm range, lag etc
  • Member For: 5y 9m 17d
I think big auto converters can get some of those big turbos moving much earlier than a manual, and stuff like antilag is becoming more common.
And yep, flow above 500-550kw is compromised. I think even forged pistons break ring lands or melt
  • Puff
  • Member For: 10y 2m 18d
  On 11/04/2021 at 2:39 AM, TRYME said:
why people like these cars with the large frame turbos e.g. gtx 42 and larger
Expand
I've got awd so it means I actually get moving instead of smoking it up. I've had 600awkw dead hook in second gear on a sticky summer hwy. Going from a 66mm garrett on a stock manifold to a 76mm aeroflow on a 6boost manifold only sacrificed about 500rpm, so I'm happy with that, and with a 3500rpm converter it will probably spool like a stock turbo car again. Also the car drives quite decently off boost so it's not slow for everyday driving.
But yerp I can see both sides of the coin, and I think awd is the saving grace for me. I reckon it would suck in a rwd car.
  On 10/04/2021 at 2:17 PM, TRYME said:
for a STREET car the GTX 3582 & G35 sized turbos (and other manufacturers equivalents) are about perfect for them lag is minimal and they make enough power to keep 99% of people happy
Expand
Haha I'm definitely the 1% :launch:
  • Puff
Nah I haven't really had any problems with it. It's made a funny noise once or twice when the power transfer through the wheels has changed rapidly but apart from that it's been ok.
  • Member For: 18y 3m 2d
Latest is I am possible off loading the 7075, and going the g35-1000, not sure to go the 1.01 or 1.21 rear.
The to4z is off the top of my head a 1.06.
Built boost from 1100rpm in top gear, 12psi by 1500rpm.
Don't mind losing a bit of low down response.
Eg. Build boost from 1500rpm min to 2000rpm max with it making 20psi by 3000rpm.
Debating to buy 1.21 giving it a go, if response is too late then buy a 1.01.
  • Member For: 4y 1m 22d
 01txr You gonna go genuine garret im
assuming?
And puff mate I think awd is your saving grace hahaha that territory sounds like a real beast 600kw Hooking up would be insane
Yeah genuine, after reading info on its build specs and the dollars spent on my engine, I've decided to go the g35-1050.
Mainly as I've found one 1.01 and .83 at a good price.
Just need to try work out which one, 1.01 or .83.
Tending towards the 1.01.
Be really good if I could find out a comparison between to4z 1.06 vs G35-1050. 83 and 1.01.
Then there's the 1.21 will it be too laggy.
Think I'll try the 1.01 and see how it performs then decide to go up or down.
Also my to4z is t4 split.
Is the vband flange better or not as good?
Theres no T4 option for the G35-1050.
And awd would be great in the falcon on street, mmmm.
But more weight and Id be worried about its strength on circuit use.
Have you looked at the Precision turbos? 6466? Or Borg Warner EFR 9180? Both of these have T4 turbine housings.
  • Member For: 14y 3m 8d
Be nice to know if garret plan on making t4 versions. Ive seen u can get g35 supercores but I assume that’s just for the vband rear housing. I think I read something that the rear housing has a different more efficient shape, maybe it all goes together better as vband?
Someone said to me a 6boost isnt that much but would be good if the g35s which are the successors to the gtx gen 2s were truly an oem replacement as their predecessors were.
6 boosts aren't overly
expensive but if you add up the price of a g35, 6 boost, dump pipe to suit, external gate set up etc it's alllooot of money over a gtx35 on a internally gated factory rear housing on a standard manifold is it better I ❤️ Bananas oath,, but it's a lot of money when the gen 2 can make 550 on the standard manifold
if a g35 would fit on standard stuff and was bolt on replacement that would be heaven haha you guys reckon they'll come down in price once they been around for a while or nah no chance?
Wonder why garret won't offer em in t4 ay,, I know a car with a BW on it apparently great turbos it's makin 630rwkw
Edited by TRYME
