Zeksta New Member 12 Member For: 4y 3d Posted 07/02/21 09:55 AM Share Posted 07/02/21 09:55 AM Hey guys, long time lurker, first time poster. I've just recently purchased an 2013 XR6 LPI and I've been hearing an odd knocking noise coming from the engine. It sounds almost as if it's coming from the exhaust manifold and may even be my catalytic converter. Taken it to mechanics and they're saying the car seems fine, taken it to a muffler specialist as well they've said there's been no issues so I'm a tad stumped. Attached is a video of the sound. Any helps would really be appreciated! Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,221 Member For: 16y 10m Gender: Male Location: Melbourne Posted 07/02/21 10:05 AM Share Posted 07/02/21 10:05 AM The LPi injectors do make a ticking noise, but not like that... that sounds more like a exhaust manifold gasket leak or maybe something further down the exhaust with a leak. Link to comment Share on other sites More sharing options...
Zeksta New Member 12 Member For: 4y 3d Posted 07/02/21 10:09 AM Author Share Posted 07/02/21 10:09 AM Yeah that's what I was thinking as well but had a muffler specialist take a look and even delve in to the catalytic converter and reckons there's nothing wrong with it or it may be melted in the middle? I'm getting a little bit of a hesitant acceleration as well and slightly lumpy idle. Pain in my ass to figure out 😂 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,221 Member For: 16y 10m Gender: Male Location: Melbourne Posted 07/02/21 10:10 AM Share Posted 07/02/21 10:10 AM yeah, that sort of symptoms does point to a collapsed catalytic converter... get it inspected by an exhaust shop via remove and inspect... they should be able to also track down where a leak would specifically emanate from. Link to comment Share on other sites More sharing options...
Zeksta New Member 12 Member For: 4y 3d Posted 07/02/21 10:16 AM Author Share Posted 07/02/21 10:16 AM Yeah was thinking might get the cat swapped as well. Can that sound also sound as if it's occuring from the engine bay as well where the exhaust manifold is? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,221 Member For: 16y 10m Gender: Male Location: Melbourne Posted 07/02/21 10:17 AM Share Posted 07/02/21 10:17 AM maybe, maybe not... depending on how the problem occurred and how it specifically occurred, but the cat is just below the rear of the engine, so it's possible. Link to comment Share on other sites More sharing options...
Zeksta New Member 12 Member For: 4y 3d Posted 07/02/21 10:21 AM Author Share Posted 07/02/21 10:21 AM (edited) Interesting, it's definitely been a touch of an annoying problem to figure out. The video I upload was just from underneath the front right wheel arch, the sound, sounds as if it's coming from the engine bay/manifold a touch more. Is it possible it could be heat shield or even sticky lifters? Edited 07/02/21 10:22 AM by Zeksta Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,221 Member For: 16y 10m Gender: Male Location: Melbourne Posted 07/02/21 10:24 AM Share Posted 07/02/21 10:24 AM yep, it's possible it's a lifter noise, but you wouldn't hear it like that, it'd mainly only be audible very close to the engine block and usually happens at the front of the engine rather than the rear (but it's possible for the rear). Heat shield is a distinct possibility but those sounds normally change with heating up and cooling down cycles of the engine and is much easier to diagnose as you can either t, see them vibrating or stop them vibrating easily to diagnose the sound. From the position you took the video, it seems likely my first suggestion is it, a multi-layered gasket leak, e.g. the manifold one. Link to comment Share on other sites More sharing options...
Zeksta New Member 12 Member For: 4y 3d Posted 07/02/21 10:28 AM Author Share Posted 07/02/21 10:28 AM Good to know! Yeah there's a bit of pinging noise that comes from engine on cold start-up which then slowly transitions into the noise you hear in the video. But either way you've been a God damn massive help! Definitely going to try to get this further diagnosed, would a gasket leak also cause hesitant acceleration and lumpy idle as well? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,221 Member For: 16y 10m Gender: Male Location: Melbourne Posted 07/02/21 10:32 AM Share Posted 07/02/21 10:32 AM That cold startup noise is probably just the gas injectors ticking and then quieting down as it gets warmer, but hard to be sure without an example. Lumpy idle and hesitant acceleration, as I said, points more towards a catalytic converter problem than a gasket leak, but if a leak is bad enough it could cause problems like that but is less likely. Link to comment Share on other sites More sharing options...
