xr6ute-t New Member 4 Member For: 4y 2m 15d Posted 04/02/21 05:48 AM Share Posted 04/02/21 05:48 AM Hi guys. After abit of advice as to an issue im having. My Xr6 turbo BA ute is having some issues. It will start and run fine until hot(talking minimum 20minutes of driving) Then intermittantly it will die. Driving along at speed(anything around 60-100kp/h) then, once stopped, it will generally not crank. Sometimes it will, and start, but then die again. After a minute or 2 it will start and run again normally.. Couple of codes shown(p1228 Wastegate not opening u1900 Comms) but not something I would relate to not cranking. Im hoping someone has come accross this issue with ideas of where to look? Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/96144-xr6-turbo-ute-dying-and-then-not-cranking/ Share on other sites More sharing options...
adams355 Member 529 Member For: 7y 11m 18d Gender: Male Location: Brisbane Posted 04/02/21 07:24 AM Share Posted 04/02/21 07:24 AM Probably the coils Link to comment https://www.fordxr6turbo.com/forum/topic/96144-xr6-turbo-ute-dying-and-then-not-cranking/#findComment-1702553 Share on other sites More sharing options...
xr6ute-t New Member 4 Member For: 4y 2m 15d Posted 04/02/21 07:50 AM Author Share Posted 04/02/21 07:50 AM Thanks for the reply Adams355, but I have never experianced non crank being caused by coils..? Link to comment https://www.fordxr6turbo.com/forum/topic/96144-xr6-turbo-ute-dying-and-then-not-cranking/#findComment-1702554 Share on other sites More sharing options...
adams355 Member 529 Member For: 7y 11m 18d Gender: Male Location: Brisbane Posted 04/02/21 09:39 AM Share Posted 04/02/21 09:39 AM (edited) As in not turn over, battery or starter or associated wiring etc. Or crank angle sensor, oxygen sensor. I can keep going. Edited 04/02/21 09:46 AM by adams355 Link to comment https://www.fordxr6turbo.com/forum/topic/96144-xr6-turbo-ute-dying-and-then-not-cranking/#findComment-1702559 Share on other sites More sharing options...
xr6ute-t New Member 4 Member For: 4y 2m 15d Posted 05/02/21 01:38 AM Author Share Posted 05/02/21 01:38 AM Please do go on. Again, I would never expect a battery to cause the engine to die.. If the alternator is charging.. Also, never heard of a starter motor causing an engine to cut out? Oxygen sensor causing no crank?? Link to comment https://www.fordxr6turbo.com/forum/topic/96144-xr6-turbo-ute-dying-and-then-not-cranking/#findComment-1702570 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,296 Member For: 10y 2m 21d Gender: Male Location: South Australia Posted 05/02/21 01:54 AM Share Posted 05/02/21 01:54 AM Get a scan tool onto it at the very least or you'll be taking a stab in the dark. On a lighter note, here's a recipe for apricot jam... Link to comment https://www.fordxr6turbo.com/forum/topic/96144-xr6-turbo-ute-dying-and-then-not-cranking/#findComment-1702572 Share on other sites More sharing options...
xr6ute-t New Member 4 Member For: 4y 2m 15d Posted 05/02/21 02:10 AM Author Share Posted 05/02/21 02:10 AM Have had a scan tool on it. P1228 wastegate not opening and u1900 comms fault Link to comment https://www.fordxr6turbo.com/forum/topic/96144-xr6-turbo-ute-dying-and-then-not-cranking/#findComment-1702573 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,296 Member For: 10y 2m 21d Gender: Male Location: South Australia Posted 05/02/21 07:27 AM Share Posted 05/02/21 07:27 AM Haha of course Link to comment https://www.fordxr6turbo.com/forum/topic/96144-xr6-turbo-ute-dying-and-then-not-cranking/#findComment-1702574 Share on other sites More sharing options...
