  • New Member
  • Member For: 4y 3m 8d
Hi guys. After abit of advice as to an issue im having.
My Xr6 turbo BA ute is having some issues. It will start and run fine until hot(talking minimum 20minutes of driving) Then intermittantly it will die. Driving along at speed(anything around 60-100kp/h) then, once stopped, it will generally not crank. Sometimes it will, and start, but then die again. After a minute or 2 it will start and run again normally.. Couple of codes shown(p1228 Wastegate not opening u1900 Comms) but not something I would relate to not cranking. Im hoping someone has come accross this issue with ideas of where to look?
Thanks
  • Member For: 8y 10d
As in not turn over, battery or starter or associated wiring etc. Or crank angle sensor, oxygen sensor. I can keep going.
Edited by adams355
  • New Member
Please do go on. Again, I would never expect a battery to cause the engine to die.. If the alternator is charging.. Also, never heard of a starter motor causing an engine to cut out? Oxygen sensor causing no crank??
  • Member For: 10y 3m 12d
  • Gender: Not Telling
Get a scan tool onto it at the very least or you'll be taking a stab in the dark.
On a lighter note, here's a recipe for apricot jam...
