djaolnes4 New Member 4 Member For: 8y 5m 8d Posted 02/02/21 12:50 PM Share Posted 02/02/21 12:50 PM I couldn't find an exact match for this when I searched, so if I have missed something, please let me know. I won't be surprised if there is an exact thread on changing the mounts.. I was trying to change the engine mounts on my FG XT turbo (not a typo, its an XT!) and I was stumped on how to do it. There wasn't enough height or clearance. I couldn't get the turbo side mount out. The passenger/inlet side is easy. There just was not enough clearance to pull out the turbo side mount. I removed all the intake plumbing, and the hot side plumbing. I undid the nuts holding the engine mounts onto the crossmember, jacked up the engine with a bit of timber under the sump, but it was still too hard to remove the turbo side mount. What I ended up doing was to remove the passenger side mount, and then jacked up the engine under the sump again, but trying to push up the sump from the turbo side to get a little bit more clearance. There is a looped pipe connection here from the powersteering (at least in mine) and you have to undo the bolt holding it to the cross member to move it out of the way. Once that is out of the way, and you push the engine across a bit to the passenger side, you can get the mount to drop in. I used a lever to try and tilt the engine up a bit, and a second person to help would have made it easier. Once the turbo side mount is in, the passenger mount is a piece of cake and can go in no problem. In the end, replacing the FG engine mounts wasn't too difficult, but knowing how to approach it makes it easier. Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,920 Member For: 16y 6m 25d Gender: Male Location: Melbourne Posted 02/02/21 12:57 PM Share Posted 02/02/21 12:57 PM for the info... seems you ran into a "turbo in a non-turbo vehicle" problem. Good job on working around it Link to comment Share on other sites More sharing options...
djaolnes4 New Member 4 Member For: 8y 5m 8d Posted 02/02/21 02:36 PM Author Share Posted 02/02/21 02:36 PM Yeah, thanks although I'm not sure its any different. The only thing I think may be different is the power steering pipe loop that was there. I am not sure if XR6T have them or not. Other than that it was a straight conversion I did years ago from a wrecked XR6T, so its essentially a XR6T. Thinking about it now, it would be the exact same problem in a NA, with minimal clearance on that side to move the mount around to get it out. If I had my engine crane assembled I probably would have attached it to the turbo side and lifted the engine that way to get the clearance needed. Link to comment Share on other sites More sharing options...
cat007 Member 236 Member For: 6y 2m Posted 15/10/22 12:54 AM Share Posted 15/10/22 12:54 AM On 03/02/2021 at 1:50 AM, djaolnes4 said: I couldn't find an exact match for this when I searched, so if I have missed something, please let me know. I won't be surprised if there is an exact thread on changing the mounts.. I was trying to change the engine mounts on my FG XT turbo (not a typo, its an XT!) and I was stumped on how to do it. There wasn't enough height or clearance. I couldn't get the turbo side mount out. The passenger/inlet side is easy. There just was not enough clearance to pull out the turbo side mount. I removed all the intake plumbing, and the hot side plumbing. I undid the nuts holding the engine mounts onto the crossmember, jacked up the engine with a bit of timber under the sump, but it was still too hard to remove the turbo side mount. What I ended up doing was to remove the passenger side mount, and then jacked up the engine under the sump again, but trying to push up the sump from the turbo side to get a little bit more clearance. There is a looped pipe connection here from the powersteering (at least in mine) and you have to undo the bolt holding it to the cross member to move it out of the way. Once that is out of the way, and you push the engine across a bit to the passenger side, you can get the mount to drop in. I used a lever to try and tilt the engine up a bit, and a second person to help would have made it easier. Once the turbo side mount is in, the passenger mount is a piece of cake and can go in no problem. In the end, replacing the FG engine mounts wasn't too difficult, but knowing how to approach it makes it easier. Sorry to dig up an old thread, but how did you get the engine up enough to be able to get even the passenger side out? Did you leave the big ali bracket that the mount bolts to, attached to the block? I can't seem to jack the engine up enough to get it out. Any more pressure and it starts to lift the car without the engine going up any more. I can't see what's stopping it going up any more - maybe the back of the engine on the tunnel/firewall? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 5m 4d Gender: Male Location: Adelaide Posted 15/10/22 06:41 AM Share Posted 15/10/22 06:41 AM Remove the aluminium engine wing bracket the mount bolts too !! x4 13mm head bolts Link to comment Share on other sites More sharing options...
