pieman18 Member 22 Member For: 13y 2m 3d Posted 30/01/21 06:43 AM Share Posted 30/01/21 06:43 AM Hey guys So I’ve got a Ford territory daily driver at the moment and there’s an issue with the passenger side window which I’m struggling to diagnose. The window is currently fully up, When you hit either up or down on the switch from either drivers door switch or passenger door switch you can hear the window motor work when it tries to wind up, but not a sound when you try to wind the window down.I thought it may have been the motor so Grabbed one from the wreckers, same problem. I then bought a new window assembly with motor and regulator, removed the old assembly and chucked the new one in, still the same issue! What could be causing the window to seemingly wind up normally, but nothing when you wanna wind it down?Could it be both switches somehow on the fritz? All other windows work perfectly from all switches. Any ideas would be very helpful! Cheers guys Link to comment https://www.fordxr6turbo.com/forum/topic/96135-power-window-issue/ Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,451 Member For: 17y 20d Gender: Male Location: Melbourne Posted 30/01/21 06:57 AM Share Posted 30/01/21 06:57 AM both switches lead to the same point, so my suspicion is that the wiring has an issue past that point. Link to comment https://www.fordxr6turbo.com/forum/topic/96135-power-window-issue/#findComment-1702438 Share on other sites More sharing options...
pieman18 Member 22 Member For: 13y 2m 3d Posted 30/01/21 07:14 AM Author Share Posted 30/01/21 07:14 AM Potential relay issue?Or more like a single wiring issue? I’ve since discovered the rear drivers window will wind down from all switches, but only up from the master switch, not the single door switchWiring problems are a little over my head Link to comment https://www.fordxr6turbo.com/forum/topic/96135-power-window-issue/#findComment-1702440 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,451 Member For: 17y 20d Gender: Male Location: Melbourne Posted 30/01/21 07:19 AM Share Posted 30/01/21 07:19 AM since it works one way, in terms of the motor trying to work, it's probably not a relay... sounds like you need the help of an auto-elec, then Link to comment https://www.fordxr6turbo.com/forum/topic/96135-power-window-issue/#findComment-1702441 Share on other sites More sharing options...
pieman18 Member 22 Member For: 13y 2m 3d Posted 30/01/21 07:30 AM Author Share Posted 30/01/21 07:30 AM Yeah that’s what I was hoping to avoidAhh well... Link to comment https://www.fordxr6turbo.com/forum/topic/96135-power-window-issue/#findComment-1702442 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,451 Member For: 17y 20d Gender: Male Location: Melbourne Posted 30/01/21 07:36 AM Share Posted 30/01/21 07:36 AM yeah, it's extremely difficult to diagnose something like what you're describing unless you're both familiar with how to diagnose wiring issues and have the wiring diagrams handy and have the ability to track the wires with regard to pulling trim etc... so it's not an ideal situation to DIY it haha, so paying somebody is not the worst scenario. Link to comment https://www.fordxr6turbo.com/forum/topic/96135-power-window-issue/#findComment-1702443 Share on other sites More sharing options...
pieman18 Member 22 Member For: 13y 2m 3d Posted 30/01/21 07:38 AM Author Share Posted 30/01/21 07:38 AM I’m in the process of selling it, so trying to get rwc, etc.Not ideal timing Thanks for your help anyway Link to comment https://www.fordxr6turbo.com/forum/topic/96135-power-window-issue/#findComment-1702444 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,451 Member For: 17y 20d Gender: Male Location: Melbourne Posted 30/01/21 08:16 AM Share Posted 30/01/21 08:16 AM selling a car tends to bring out the niggles that cost a bit of money, eh... then you're like... should I keep it? haha that's how it goes... Link to comment https://www.fordxr6turbo.com/forum/topic/96135-power-window-issue/#findComment-1702445 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 27d Gender: Male Location: Townsville Posted 10/02/21 09:13 AM Share Posted 10/02/21 09:13 AM @pieman18 Jump on the Ford forums under their technical knowledge section they'll have wiring diagrams for the Terry.Have you tried using the rear opposite switch assembly (swap them) to see if the dodgy side works? Unsure if it'll fit in the front though Link to comment https://www.fordxr6turbo.com/forum/topic/96135-power-window-issue/#findComment-1702683 Share on other sites More sharing options...
