  • Cruise Control
  • Member For: 18y 4m 26d
Guys Im running a BF F6 with 4" dump, 6" cat and dual 2.5 exhaust...
The H brace that supports the Turbo is buggered and I want to do away with it because its a bitch to get on and off.
So I'd like to know if anybody has come up with a better way to support the weight of the front half of the exhaust system?
The manifold, turbo and dump adds up to a lot of weight hanging by the manifold studs...
I can make a bracket that will hold the system at the back of the cat but thought I'd run it by you guys in case somebody has come up with a better idea?
Thanks guys....
https://www.fordxr6turbo.com/forum/topic/96076-front-exhaust-support-on-bf-f6/
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 1m 15d
Since you already have manifold studs, replace the washers that go on them for nordloc washers and do the same with the exhaust-manifold-to-turbocharger with nordloc too and then they'll stay tight and won't have an issue holding up the weight without the H-brace. I've taken off the H-brace before without bothering to replace the manifold-to-head bolts with studs at all and just done the manifold-to-turbocharger studs/nuts and added nordloc without any issues with sagging etc.
  • Member For: 10y 3m 25d
  • Gender: Not Telling
I put the factory stuff back and just deal with the pita that it is. It's a pain but that's just part of life hey.
I'd expect a workshop to do it properly so yerp :idunno:
  • Cruise Control
Hi k31th...
I thought I'd get away with it but since the H brace has gone I've started cracking the dump pipe around the flange where it bolts to the turbo...
I've migged it up with some bracing around the top flange but I reckon it'll break again with the amount of weight hanging off it...🤔
  • 1 month later...
  • Site Developer
stock or aftermarket? I've seen the welds on aftermarket ones crack, but never seen a stock one do it.
